Won't start (but trying) II
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Gators91TransAm - I'm sorry in that I played a part in screwing your last thread, let me recap:
"My wife was driving the car (91 TA w/305) and it hesitated. She let off the gas, then it backfired when she gave it gas again. She pulled over, shut it off, and it would not start again.
The motor turns, and I can hear the fuel pump initializing. But it won't catch. "
You replaced the ignition module and plugs. We ruled out the timing chain being broken.
We are now waiting to see if you got any codes and if you can check the fuel pressure. Also a check on the EGR was suggested as well as a verification of TDC and rotor position.
Hope I didn't miss anything, and again I apologise for partaking in the thread hijack.
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
wont start
You should start with getting a fuel pressure gauge and check it at the rail near the distributor, all because you hear the pump doesnt mean that it still is capable of building up enough pressure to fire a group of injectors enough for the motor to fire.
If you dont have a fuel pressure gauge maybe this might help with out the gauge.
I personally would get someone to turn your accessories to the ON position allow the pump to prime(3secs) and then press the schraeder valve on the fuel rail if fuel just trickles out your fuel pumps bad if it has very strong pressure and hits the roof of your hood then maybe not.( wearing safety glasses wont hurt gas in your eye will )
<< note the closed eye...lol
<< note the closed eye...lol Junior Member
Car: 91 Trans Am
Engine: 5.0 TPI
I have not pulled the codes yet, but a buddy is bringing over his lil scan tool tomorrow to help with that.
Until then, I'll try the fuel check you suggested and see what we get.
Thanks again!
Thanks again!
Checking the codes takes 5 minutes and a paper clip, that's why I suggested it
Read about it on the FAQ https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Read about it on the FAQ https://www.thirdgen.org/newdesign/faq/thirdgen.shtml Junior Member
Car: 91 Trans Am
Engine: 5.0 TPI
Okay...gave me '12', which is "No reference pulses to ECM".
Does this mean the ECM is bad? Or...? Can I test it?
This sucks, but explains the no start condition, eh?
Car: Tree Huggers
Engine: Do Not
The list is correct. Nor reference pulses from the distributor to the ECM. Makes perfect sense if you stop and think about it.
Car: 91 Trans Am
Engine: 5.0 TPI
Meaning that, according to the OBD, nothing is wrong? Or...? I don't know enough about how the system works to draw an accurate conclusion.
I suppose I'll know more once I get the scan tool hooked up.
Car: Tree Huggers
Engine: Do Not
There is no reference pulse coming from the dizzy because the dizzy is no workie if the motor isn't running.
Test the fuel pressure, and pull a few plugs and see what they say. Was it running really rich just before it happened? Whenit turns over is there a strong smell of fuel?
Car: 91 Trans Am
Engine: 5.0 TPI
I don't know if it was running really rich. Fuel mileage and performance didn't change, as far as I can tell.
I pulled the plugs (replaced, actually), and all showed signs of a normal burn. They were out of gap based on age, but were fine other than that.
Yes, there is a strong smell of fuel when trying to start it.
wont start
Gator do you know how to confirm that you are getting spark to your spark plugs ?? by using a jumper wire ??
did you try the fuel pressure trick yet??
Originally posted by Gators91TransAm
We used the old screwdriver and a ground trick for the spark. What fuel pressure trick are you talking about? I'm gonna try and do some more tonight...
Just in case you have eliminated spark as the problem, seeing a spark doesn't mean anything if the car won't start
You need to use a spark checker to make sure you've got adequate spark, your coil or some other ignition component could be fried.
You need to use a spark checker to make sure you've got adequate spark, your coil or some other ignition component could be fried. Senior Member
You need to use a spark checker to make sure you've got adequate spark, your coil or some other ignition component could be fried. NOOOOOOOOOTTTTTTTTTT
If somthing in his ignition were fried he wouldnt get a spark at all.!
Car: Tree Huggers
Engine: Do Not
Originally posted by robsgta
...If somthing in his ignition were fried he wouldnt get a spark at all.!
Never heard of a weak spark huh?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The schraeder valve is located on top the passenger side fuel rail near the back. Looks like a tire valve stem and might have a back dust cap on it.
Yeah what he said..Its behind the small vacume hose that hooks near the back corner of the plenum pass. side of coarse.
Mine has a small aluminum cap .
Car: 91 Trans Am
Engine: 5.0 TPI
Shot fuel out, but it was just a small shot...I guess I should try and find a fuel pressure gauge to do this correctly, but it apears the pressure is good.
So far, I've replaced the ignition module, cap and rotor, plugs. I've verified spark (but not with a spark checker) and fuel (though not with a pressure gauge). I've checked codes, got repeating 12. That's it, and I'm stumped. Car will turn over fine, but will not start.
Damn I've never had a problem kick my *** like this before. I'll be pissed if I have to take it to a shop...lol...
Car: 91 Trans Am
Engine: 5.0 TPI
What's normal spark? I got a spark checker, one of the screw types with an alligator clip. The screw is adjustable out to 40, but I'm curious what would constitute a 'good' spark.
Anyone?
Anyone?
Car: 91 Trans Am
Engine: 5.0 TPI
Got it running...with the spark tester hooked up, I was getting a very weak spark. I replaced the coil pack, and she cranked right up.
I appreciate all of the help you guys have given me with this. I feel like an idiot that it was something so simple, but at least I got a good tune-up out of the deal. Total cost was prob. around $60, so I don't feel like I just kept throwing money at it. I just wish I'd gotten the spark tester earlier so I'd have been able to better gauge the spark.
Thanks again, guys! Until next time...
Help
Can Anybody help me i am having a problem my car will not start i dont hear the fuel pump prime i found out that the fuel pump relay was bad and i i replaced it.my car then started and was running but then the next mourning my fuel pump wouldn't prime so can somebody give me ideas or helpfull information so i could get my car running for work tomorrow
thanks in advance
thanks in advance
Um yeah its your fuel pump going out. Not your relay...Get a fuel pressure gauge and check the fuel pressure on the schraeder valve near the distributor on the passengers side I will bet the pressure is weak & drops immediately
rob
rob
