Cam Swap
Old Jul 11, 2004 | 04:31 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Cam Swap
Hey guys I'm changing out the timing chain on my 305 any day now and have an L98 cam sitting here that I'm thinking, why not put this in for the time being. Anyways, say I have the radiator dropped already, will I need to pull the nose off the car to swap cams or is there enough room to swap without taking the nose off? Let me know what needs to move. Thanks guys.
Old Jul 11, 2004 | 05:13 PM
nsimmons's Avatar
there 2 cross support beams that run in a diagonal pattern across the front of the car, the cam wont clear them..you'll get the cam 95% out and it'll hit the bars, just undo the top bolts and slide them out of the way.
Old Jul 11, 2004 | 09:38 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I had a friend yank up on them while i pulled th ecam out. I snuck under them.
Old Jul 11, 2004 | 09:44 PM
nsimmons's Avatar
that works too i guess..
Old Jul 11, 2004 | 09:59 PM
BronYrAur's Avatar
Engine: 305 TBI
Ok, sounds good to me, I didn't want to be pulling the nose off. Thanks guys.
Old Jul 11, 2004 | 10:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Do you have an AC condenser? If so, that needs to be slid out of the way as well.
Oh side suggestion: Do you have one of those sockets that fit over the crankshaft snout? if so, after you remove the timing cover, rotate the engine to align the gears dot to dot. Makes things easy for installation. Just install the gears dot to dot and drop the distrib, pointing to #6.
Old Jul 11, 2004 | 11:44 PM
BronYrAur's Avatar
Engine: 305 TBI
Yeah, I have A/C, so I guess I'll have to move that out of the way then. I should be able to get a hold of a socket to fit, thanks for the suggestion, I'll do that.
Old Jul 11, 2004 | 11:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
http://store.summitracing.com/partde...N=120%20300354
That's what i have.
anesthes
Mar 10, 2016 10:35 PM
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
