I Need Answers!!!!!
I Need Answers!!!!!
I have a 91 rs camaro and There is some stuff wrong with my car that i need to know what to do. Like sometimes when i drive my car when i push down on the gas it takes it a while to catch acceleration and actually go and even when ive had my foot on the gas it still seems like its trying to keep going and if i stomp on it to really go it like sounds like its hitting the floor and it will make a pop noise right under the console it sounds like but it sounds like something is scrapping inside or something the after it switches gears cause its a automatic it will make the popping noise but i dont know whats wrong with it i just need to know why its doing that so i can know what to get
Car: 4
Engine: 6
Transmission: 5
The noise is probably the transmission and/or drive shaft hitting the bottom of th ecar, because the trans mount is broken.
Get a poly one from Energy Suspension or Prothane. If you replace it with a rubber one, it will just break again.
Car: 91 RS
Engine: 305 Tbi (L03)
Please use a . somewhere. The poping you hear when you accelerate kinda sounds like a bad trans mount. As far as the no acceleration you need to let us know a little more as to what the engine and vehicle speeds are when its happening.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Sounds like a tranny problem to me, more specifically the torque converter. Maybe the stator is bad.
HoosierinWA
Oct 7, 2015 10:15 AM
