Fan wont cut on with AC!!!
Old Apr 23, 2001 | 10:00 PM
LottaBallsCamaro's Avatar
I havent had time to check it out, but I'm 90% sure that temp wont cut it on either. What should I check for? This sucks!!!
With this car, it's never a question of "can I...", only "will I..."!
Old Apr 24, 2001 | 09:47 AM
BrianB's Avatar
If the tempature of the car won't kick it on either, it could be the tempature switch that is bolted directly into the block between the number 6 and 8 plugs. These are on the passenger side of the car. First I would check to make sure the fan motor is still working. Do this by locating the fan relay. Unplug it, and turn the key in the on position. On the plug end find the hot wire, usually black with a red stripe. Plug a wire into it, then take that same wire and plug it into the ground on the same plug. The fan should kick on. If not then you need a new fan motor.
Old Apr 24, 2001 | 10:12 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
so your aware, if ya trace the wires back, the fan relay is mounted on the firewall to the drivers side of the brake booster.
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, 1 inch carb spacer, Fiberglass cowl induction hood, Formula wheels, vette servo.
Current Plans: Waiting on: rear end parts- upgrading to 373's, 28 spline axels, slp zexel torsion posi, and a disk brake setup. Also have lowering springs, front struts, and hopefully a new mild 350.
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Apr 24, 2001 | 10:15 AM
rondubbs's Avatar
it also may be the fusible link or just the fuse. check those both out.
Old Apr 24, 2001 | 06:03 PM
I've checked the fuse already and when my girlfriend gets back with the car, I'll check the fan. What I really needed to know is how to check the relay itself???
Old Apr 24, 2001 | 06:13 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
I would put my money on your freon charge. If you don't have enough freon in the A/C system, you won't build up enough head pressure and the fan won't turn on. Check your freon content.... I'll bet it's low or not even there.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 24, 2001 | 07:29 PM
The AC works(and good as hell too)...
Old Apr 24, 2001 | 08:13 PM
Car: 1985 Trans Am
Damn.... good thing no one took me up on that bet...
Kevin Irving
Old Apr 24, 2001 | 10:09 PM
jdb8797's Avatar
If you need a quick fix while you figure something out, buy a $3 fog lamp relay from Auto Zone. Splice as wire off the hot (green?) wire going to the AC compressor to act at the activator. Splice into the fan's hot wire, and connect the relay to the battery, and you're ready to go. I have been around the block with fans and fan wiring. Now both my fans run off fog lamp relays. One is AC activated, the other ignition activated. Ideal: No. Works: Yes. The best solution after 100 hours of fruitless labor trying to fix the stock system: Definitely.
Jeff
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
