VAlVE COVER LEAK UNSTOPABLE!!!
Old Aug 23, 2004 | 09:34 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
I bought MOROSO Red anodized valve covers and their matching $35 dollar gaskets from Summit and i cannot get the damn things to seal for the life of me....first i just put them on normal...leaked like hell...then i put a 1/4" bead of RTV on the valve cover and sealed the gasket to the valve cover...i am 100% sure that this seal is not causing the leak..then i let them dry completely and put them on the car and....nothing..still leaks like hell..I can watch oil leak from in between the heads and valve covers still when the car's running.
Does anyone know how to fix the problem w/o dipping the entire engine in R.T.V???
If not, then what recommendations do you have for a thicker less bendable valve cover???
Thanks,
25thredrs
Old Aug 23, 2004 | 09:53 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Only other thing to try w/ those covers IMO is to put a thin layer of RTV on the side of the gasket between the head and the gasket... only way I could get my peremiter bolt VCs to not leak... makes clean up a little worse when you take them off, but I just put enough spread out with my finger to make it seal... so its not that bad.
Old Aug 23, 2004 | 09:56 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Do a close inspection of the valve cover and make sure it is not slightly dented or something where leak is. Chekc the block also and make sure there are no impurities on that spot. I know that sounds pretty simple but evan the smallest thing can cause a problem.
Also lay the valve cover on something you know is flat and check to see if it is warped.
Old Aug 23, 2004 | 09:58 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
it shouldn't be leaking that much, theres gotta be something wrong with either the head or the valve cover
Old Aug 23, 2004 | 10:34 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
I even bought the valve cover hold down's that more evenly disperse the pressure over a more broad span on the edge of the valve cover.
I am thinking about just returning these covers and buying a thick set of stamped steel sets that wont bend
Old Aug 23, 2004 | 11:01 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
cast aluminum covers work for me ... not real pretty and shiny but they dont seem to leak ... tao
Old Aug 24, 2004 | 08:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like they're not even touching the heads.
You don't by any chance have roller rockers, do you? Sounds like the VCs are sitting on top of the Poly-Locks, and aren't tall enough for the flange to reach the head.
I'd strongly recommend getting something else.
For example, I'm running the ProForm ones you can get from SDPC among other places; they have the factory style oil baffles and therefore support PCV without leaks or spewing oil mist unlike those stupid push-in breathers you're usually stuck with when you run aftermarket VCs. Only problems with them are, you have to munge the baffle (smash it) to get it to fit between the rocker trunnions; and they don't have a separate place to add oil. You have to add it through the PCV holes which is kind of slow.
Old Aug 24, 2004 | 10:12 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
Yes i do have 1.5 roller rockers but the valve covers are the tall style and are not resting on or even touching the rockers. They are plenty tall...i think the valve covers are just warped to hell and back....what's SDPC?
thanks,
25thredrs
Old Aug 24, 2004 | 10:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
www.sdpc2000.com
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
