i think i seriously screwed up...
Old Aug 26, 2004 | 11:47 PM
jfawcett10's Avatar
Car: 1987 Formula Firebird
Engine: 350carb
A bolt managed to break off in the manifold while i was bolting down the carb.
Then to make matters worse, the easy-out bit broke off in the hole while getting the bolt out.
What do i do now?
I think i should take the manifold off, stick it on a drill press and see if i cant bore out the hole, and then thread it.
Does anyone else have any ideas???
(and dont say, shouldnt have done it in the first place, i heard it all day )
Thanks to anyone who can help me...
jarrod
Old Aug 27, 2004 | 12:13 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
it is extremely hard to get an easy out, a regular drill bit won't touch it, a hardend bit won't last to long. i have seen my boss get them out, but i don't see how. that's what years and years of being a mechanic and breaking **** will do. it's possible, depending on how bad it is, you might not be able to get it out. hopefully that isn't the case.
Old Aug 27, 2004 | 04:12 AM
ede's Avatar
ede
too late now but you should of forgot the easy out. there is a very narrow application range where they are the tool of choice and your broken bolt wasn't it. you'd been way ahead to drill and tap instead of use the easy out. now since you did and you're pretty much intercoursed the thing to do would be weld a nut on the stub and back it out with a wrench. if the nut comes off weld another on till it's out.
Old Aug 27, 2004 | 04:15 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
yea, i agree with the welding a nut on trick. i have used the same trick countless times and it works wonderfully, normally the first time. otherwise, buy a FEW titanium drill bits and make patience your virtue...
good luck
Josh
Old Aug 27, 2004 | 06:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What kind of a manifold is this?
If it's a stock LG4 manifold or something, it isn't worth spending money on to save it. Replace it.
Old Aug 27, 2004 | 06:43 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Easyouts are a PITA to remove, welding is the prefered first choice, but if that fails or the thing is broken off deep then the manifold may need to be taken to a REAL machine shop with a milling machine, they can mount up the intake and use a carbide endmill cut the easyout out, I've done this many times at the shop I work at, a carbide endmill will cut through an easyout like butter, but it won't be cheap doing it that way.
Old Aug 27, 2004 | 07:49 AM
DonP's Avatar
Car: 1990 GTA Black/Black lthr
Engine: 305 TPI stock
Re: i think i seriously screwed up...
I guess you were making sure that carb wasn't going to fly away LOL!
I'd be surprised if you didn't warp or crack the carb base plate.
Old Aug 27, 2004 | 01:08 PM
jfawcett10's Avatar
Engine: 350carb
the carb is fine, the bolt was half way threaded then broke off...
also, there is no stub of the bolt, it broke fluch with the manifold, as did the easy out bit...
yes, its an LG4 intake manifold...
thanks for all the suggestions, if i cant get it out, i guess i ll just get a new manifold...
Old Aug 27, 2004 | 01:19 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get a rotary tool (or a hacksaw) and cut a slot in the part of the bolt that you can reach... then you might be able to back it out with a screwdriver or a flat screwdriver-tip on a ratchet. Its worked for me.
Old Aug 27, 2004 | 01:32 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
either that or weld it up, persoanlly i'll just go out and get a new one
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
