Engine and Tranny match up
Old Sep 23, 2004 | 10:21 PM
bbigbrn612's Avatar
Car: 1984 z28
ok say i took a 350 wih a two bolt main, would a t-56 6 speed be good? i want a 6 speed for my car but is there another one that would be better?
Old Sep 24, 2004 | 05:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It would work fine, as far as that goes. You might need the $special$ adapter flywheel, depending on the 350 you choose.
I was just up in Brecksville a couple of weeks ago, building a radio station. You might possibly even have seen my car, if you live in the southwest part of town, since I was using it as a work truck.
Old Sep 24, 2004 | 12:46 PM
bbigbrn612's Avatar
Car: 1984 z28
maybe, tell me next time you come up ill show ya my car if ya want. is there any other 6 speed thats good, thats other than a t-56? i want it to be as good as the t-56 and have some good torq so i can show off to the ladies.
Old Sep 24, 2004 | 12:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I couldn't say about "as good"; the T-56 is one that you can get at the junkyard, and it fits the car, so I guess that's pretty good.
Transmissions don't "have torque". Engines have that. Transmissions merely survive (or not) when torque is applied to them.
Old Sep 24, 2004 | 02:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OBTW, I did eat at Whitey's Booze & Burgers while I was up there.... that Kiev Burger is one hell of a plateful.... thank goodness they don't put their whole name on their receipts, otherwise it might raise eyebrows when I file my expense report.
Old Sep 24, 2004 | 03:19 PM
bbigbrn612's Avatar
Car: 1984 z28
ok so the tranny from a junk yard. how much should i be able to get one for? obviously have to do a rebuild.
Old Sep 24, 2004 | 03:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Depends on the yard more than anything else. If they know what it is (ie. its from a Camaro/Firebird) expect that to jack up the price some.
RB... you have a 6-speed right? Or are you on #__ T5?
Old Sep 24, 2004 | 03:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You'll be looking for the trans from a 93-97 (probably you'd really prefer 94-97) Z28 or Trans Am. Shouldn't need a rebuild.... that's why this is the trans you want in the first place, is because it doesn't tear up much.
Make sure you get every possible piece: the bell housing, the little spacer piece that goes under the slave cyl, the complete hydraulics themselves, the shifter, the flywheel, the clutch. Pay extra if you have to, it's cheaper than buying them new. Probably be around $1200 for all that.
Yes, I swapped to a T-56; I'm done with T-5s.
Old Sep 24, 2004 | 07:36 PM
bbigbrn612's Avatar
Car: 1984 z28
its auto currently, why would i not rebuild a used tranny? thats only if the gears are worn right?
Old Sep 25, 2004 | 02:33 PM
Air_Adam's Avatar
Cuz its probably not nessesary (sp?). You rebuild it when bearings, seals, and syncros are worn out. If the gears are worn out, look for another one.
Old Sep 25, 2004 | 02:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's the point. You don't replace gears when you "rebuild" a transmission, ordinarily; just the wear parts, such as bearings, seals, etc. Gears are expensive.
If you get a trans at the boneyard that needs gears, you just take it back, tell them it's fornicated, and you want another one. And keep doing that until you get a nice cherry one. But most likely you won't have alot of trouble with that, because that's why you're looking for a T-56 in the first place: they don't wear out much, so any one you find in the yard, is probably going to be OK anyway.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
