TPI to Carb Swap--Will This Set-Up Work
Old Sep 24, 2004 | 10:55 AM
87camz28's Avatar
Car: 1987 Camaro Z28
Engine: 5.7L, L98 slightly modified
I am switching my TPI to a carb setup. I have a Holley 600cfm (pn1850-c) carb from a previous motor and a Weiand X-CELerator intake manifold(pn 7547) also from that motor. Right now I have a stock L98 with headers, 3" exhaust and a Flowmaster 80 series muffler. I plan to upgrade to better heads and a cam as well as a higher stall TCC and a 3.73 gear. My question is will the holley carb and the Weiand manifold work okay until I can afford to do the upgrades mentioned above?
The intake is a single plane with a range of 2000-6500RPM's. Any advice is appreciated.
Old Sep 24, 2004 | 11:41 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
It should work with the few mods that you do have. most people will tell you that with a single plan manifold you may sacrifice low end. what do you plan on doing with the car? daily driver? weekend warrior? both?
Old Sep 24, 2004 | 12:51 PM
87camz28's Avatar
I basically want something that will eventually have close to 400 hp that can be driven on the street, but occasionally take a trip down the strip too. It won't be a daily driver.
I used to have an 81 Camaro that I built a monster 355 for, the problem was I could only enjoy the power at the track and that eventually led me to sell it.
Old Sep 24, 2004 | 02:20 PM
-ZERO-'s Avatar
Engine: 305 H.O.
if your looking to get up to 400 hp you probably need to get a bigger carb, say a holly 700cfm DP and if its gonna see more street use. a dual plane intake will give you more lowend so when your at a red light and some kid in a honda revs his motor at you, you can leave his booty in your rearview! LOL I only have a stock 305 in my 86 and just put a performer RPM airgap ( dual plane ) on it a week ago and noticed big improvement. motor has like 220,000 miles on it and still runs pretty good. 350 is going in soon!
Old Sep 24, 2004 | 02:52 PM
87camz28's Avatar
Yeah, I had a Holley 750 double pumper from the motor out of the 81 Camaro but I sold it a while back. I had the Holley 600 and was going to use it until I invested in better heads, cam and other stuff.
I agree about the dual plane for street use, I still had the Weiand manifold and was trying to use it instead of buying a new dual plane. The more money I can save, the more money I can spend on other go fast goodies!
Old Sep 24, 2004 | 03:05 PM
-ZERO-'s Avatar
Engine: 305 H.O.
Amen to that!
I say use the single plane and run it. if you dont like it, put the dual plane on your christmas list
Old Sep 27, 2004 | 07:11 AM
87camz28's Avatar
That's my plan. I hope to have some other work finished on the car by the first of the year, that way I can really start concentrating on the powerplant.
Old Sep 27, 2004 | 11:15 AM
-ZERO-'s Avatar
Engine: 305 H.O.
Soon you'll be doing this... Good luck with your project!
Old Sep 27, 2004 | 12:44 PM
87camz28's Avatar
Thanks, good luck to you too!!!
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
