Camaro intake ducts on a firebird?
Old Sep 26, 2004 | 11:07 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey I just noticed this in a pic I had. An early firebird with a tpi has intake piping from a camaro. Did he just take the upper piece that connects the radiator support to the bumper and use the intake ducts? If so, it looks pretty effective.
I thought their wasn't hood clearence for this. You can see through the hood where it appears to be a factory cowl induction hood(is that what it's called?).
Old Sep 27, 2004 | 07:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Even if those ducts fit, they don't work.... in a Camaro, they collect air from above the headlights,which is of course a direct path to the outside world that's missing from a Firebird.
Old Sep 27, 2004 | 10:13 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i've thought about that before, but i think the heat from 8 halogen bulbs would negate any benefits i'd see.
Old Sep 27, 2004 | 01:26 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Couldn't they be fabbed up to collect air from under the front end? Kind of like a ram air setup?
Old Sep 27, 2004 | 01:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Actually, that setup isn't the one I thought it was when I first looked at it (I went back and image-processed it so I could actually see what it was); that's the TPI intake for a Camaro in the pic, not the L69 one. Frankly I have no idea whether that will fit in a Firebird without modifying anything. I'd think that if it would, the factory wouldn't have put in that power-robbing thing with the 90°, but I don't know for sure. In any case, it gets its air from the same "plenum" that the radiator does, not from the headlight area, like the L69 ducts.
Old Sep 27, 2004 | 02:03 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
You had me really confused for a second.
This guy/girl was at the TA Nationals in 2003.
Old Sep 28, 2004 | 01:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
RB, yeah, there's almost no clearance between the top of the rad support and my Firebird's sloping hood. (Measured it with a crumpled piece of paper, it squashed it pretty good) Never tried to fit a TPI intake there, though- it looks like IT would get squashed pretty good!
I guess if the rad support was notched somehow...? Actually- wait, in that picture... is it? Can you see the rad support in your processed image?
Old Sep 28, 2004 | 06:13 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Are you saying the Firebirds did not come with the dual snorkel air cleaner from the factory, or are you saying they did but were just not as effective as they were on the Camaro?
Old Sep 28, 2004 | 08:38 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
It would definitely take some fab work to get that to work right, or at all for that matter. The firebirds nose slopes a lot more than the camaro. Not noticeable unless you compare side to side. This makes for less clearance between the radiator support and the hood that follows the same lines as the fenders.
Old Sep 29, 2004 | 10:07 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I'm curious as well, did L69 birds come with the dual snorkel?
Old Sep 29, 2004 | 10:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Aa far as I can recall, they did not.... there's nowhere for them to go to. The hood would just slam on them and smother the end of them.
Go look at a Camaro, and then look at a Firebird, and it won't be too hard to figure out why the Pontiac won't accommodate them.
The pic isn't high enough resolution to see what was done to get that Camaro TPI duct into it. I can't see how modifying the core support would be possible, becaure the rad itself, and the condenser, would still be in the way, about ½" below where the core support is. The only way I can see that it would be possible, is by modifying the hood. But again, the pic resolution isn't good enough to see the hood down to that level of detail.
Old Sep 29, 2004 | 04:03 PM
Nate86's Avatar
Engine: 4 cylinder
What would be a good cool air intake for an LG4 Trans Am? And why did they even bother with the single snorkel in the first place if it doesn't flow at all?
Old Sep 29, 2004 | 04:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have no clue.
That's one of the reasons I have a Camaro, actually..... the TA L69 had noticeably less seat of the pants than the Camaro version did. I didn't even bother with any LG4 or CFI ones.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
