Starter wiring "R" terminal??
Old Nov 20, 2004 | 05:50 AM
FireBoid's Avatar
Car: 1987 Firebird, 1997 Camaro
Engine: 2.8L, 3.8L
Transmission: T5, 4L60E
I'm putting in a replacement starter. Original has 3 terminals, Main to battery and fusable links, "S" for key wire, and "R" for??? The new starter only has Main and "S". Does anyone know what the "R" terminal is for, and do I need it?
Old Nov 20, 2004 | 06:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes someone knows. I do, for example.
No, you don't need it; unless you're running an old points type ignition, from the early 70s or before.
Old Nov 20, 2004 | 07:10 AM
FireBoid's Avatar
Engine: 2.8L, 3.8L
Thanks. It's an '87 and the wire that attaches to it is there?? Go figure!
Old Nov 20, 2004 | 07:25 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Wonder if that is for the cold start injector circuit?
Old Nov 20, 2004 | 07:59 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I'm pretty sure that its an engine crank signal for accessory power cutout during start up.
Old Nov 21, 2004 | 05:40 AM
FireBoid's Avatar
Engine: 2.8L, 3.8L
If it's an accessory cut out I'm not too worried about it, but if it's related to cold start it's getting to look alot like X-mass here in upstate NY and I'll be needing that. Does anyone know for sure. It's not even in the schematic in the Haynes manual. Haven't checked Chilton yet.
Old Nov 21, 2004 | 06:37 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
My 87 schematic shows cold start switch and injector running off of the purple and white wire that goes to the "s" terminal. It shoots off somewhere in the harness and not from the starter "r" terminal.
Old Nov 25, 2004 | 10:44 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
LOL. The cold start injecton is controlled by the ECM..not the starter.
Old Nov 25, 2004 | 11:29 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Actually, I BELIEVE it is controlled by the "switch" next to the temp sensor on the front of the intake. If you notice, the sensor for the cold start is significantly bigger than the temp sensor because it is actually a switch.
Old Nov 28, 2004 | 09:33 PM
84L69TA's Avatar
Car: 4 Mopars total
Yes, the temp switch is also wired into the system...but the ECM actually controls the injector, when the temp switch tells it to.
Old Nov 28, 2004 | 11:47 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Nope, the cold start injector is directly controlled by the cold start injector switch and has no ECM input in the system at all. It is an independent system.
Old Nov 28, 2004 | 11:50 PM
Matt87GTA's Avatar
Here's a diagram:
Old Nov 29, 2004 | 04:52 AM
FireBoid's Avatar
Engine: 2.8L, 3.8L
Thanks Mat. Matter put to bed.
Bill
Caspar
Jun 19, 2016 11:19 PM
db057
Sep 4, 2015 07:57 AM
Jae992
Aug 27, 2015 09:07 AM
Accerrito22
Aug 23, 2015 07:22 PM
