Replace 1 piece RMS?
Old Nov 30, 2004 | 03:29 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have the engine out of the car to replace the oil pan gasket. and do some detailing.
Question is my 89000 mile 305 has the factory 1 piece Rear main seal that is not leaking.
Since the engine is out should I:
1. Replace because it is there in front of me. (Risk possible leak with new seal. It has happened to me once....)
or
2. Leave the seal alone since it is not leaking and take my chances that it will not leak in the future?
What do you experieced engine wrench heads think?
Old Nov 30, 2004 | 03:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I had planned on replacing mine when I had the engine out at 141k for the upgrades. However, I couldn't get the flexplate bolts loose (still puzzled over that one), so I just left it. Currently 166k miles, still doesn't leak.
Old Nov 30, 2004 | 03:44 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
if it ain't broke, don't fix it, your just inviting problems with it
Old Nov 30, 2004 | 06:28 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I say change it. It only takes 5 minutes. Better to do it now than to pull the trans out a month down the road if it decides to start leaking.
Old Nov 30, 2004 | 09:43 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Cost for a rear seal is fairly low, I go 1982t-topTA, change it.
Old Nov 30, 2004 | 10:59 PM
VILeninDM's Avatar
I also vote for change it. seals do wear and I'd say the chance of new one leaking is still less than the chance of old one leaking (if not now than in 20k miles). This is especially true if new seal is not installed with a screw driver, but that's a different dodge neon story.
And look at it this way, right now it costs you few bucks more and 15 minutes. If it starts leaking later, you'd still have to do the same work of pulling the tranny.
Old Dec 1, 2004 | 09:07 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
another vote to change it... i think the chances of it not leaking after replacing it are better than potential leaks from wear and time with the old one.
KAM
Old Dec 1, 2004 | 09:10 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if the engine is already out id change it along with any other gaskets you can while its easily accessable..
Old Dec 1, 2004 | 12:48 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Change it, I change mine everytime I changed the clutch. Its like $8 and takes 3 minutes.
Old Dec 1, 2004 | 01:28 PM
five7kid's Avatar
I guess I should have said: If I was using a petroleum-based engine oil (which I am not), I'd probably change it. A good synthetic engine oil will keep the seal pliable and reduce wear.
Old Dec 1, 2004 | 01:29 PM
THEGENERAL's Avatar
another advantage of synthetic
Vintageracer
Jan 10, 2020 05:33 PM
Reborn756
Sep 4, 2015 03:42 AM
MY87LT
Aug 17, 2015 08:43 AM
TheJoeY88
Aug 13, 2015 06:51 PM
89FormulaMan
Aug 10, 2015 10:01 PM
