Getting oil dipstick tube out
Car: 1985 Z28
I have done a search for this but i couldnt find anything related to my certain problem. The guy who had the car before me for some strange reason believed it was alright to cut the dipstick tube near the block as close as he could. Saved weight? but i there was enough i pulled and twisted and a piece about an inch or so long came out it was clean cut on the bottom (the portion in the block) you can see there is still a portion of tube in the hole. is my only solution taking the oil pan off and trying to tap it out. or is this impossible? any suggestions greatly appreciated
Ryan
Ryan
Transmission: 4L80E/4L80E
Had you intended on posting a picture?
What's the vintage of this 350?
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Find a bolt that fits the hole and knock the piece down and into the oil pan. It cannot get sucked up by the screen it is too large.
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
disregard my last post. I reread and see it is an earloer block. There is a flared sleeve in the block that drops in before the dipstick goes in. This may be the piece you see. Late model blocks do not have this extension. Post a pic. You may be in good shape already.
Car: 1985 Z28
what about a new tube? the reason i was posting was because i could not get the new tube in or is there another part number i need for this style
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
There are lots of choices. Lokar makes some nice dipsticks for a pre 80 block. I bought a braided steel, with billet handle from them for about $40. Chromies , and oem type are all out there. I ordered a plain Jane dipstick from my local chevy dealer for the last motor I assembled. Easy to find. Aftermarket stuff usually comes with tube.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
