trans cooler lines?
Old Jan 8, 2005 | 12:28 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
trans cooler lines?
Alright I just bought an aftermarket trans cooler for my car and I need to know which line is the inlet line and which is the return line. Thanks.
Old Jan 8, 2005 | 12:41 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Bottom line from transmission to factory cooler in the radiator, top line from factory cooler in the radiator to transmission. So the top one at the radiator is the return. Don't remember which one it is a the trans. Just trace it back from the radiator.
Old Jan 8, 2005 | 12:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Top port on the rad connects to top port on the transmission.
Old Jan 8, 2005 | 12:57 PM
IROCaholic's Avatar
Car: 89 Camaro RS
so the top port at the rad returns the fluid to the trans correct?
Old Jan 8, 2005 | 01:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, which goes into the top port on the transmission.
Old Jan 8, 2005 | 06:22 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Alright now the trans cooler is hooked up and my car is actually running alot hotter. Do I need to plug the holes for the trans lines in the radiator?
Old Jan 8, 2005 | 07:52 PM
IroczInOz's Avatar
I did not plug the holes that are left when you unplug the trans lines when connecting a cooler. Just leave them as is.
Does your trans cooler have to be connected outlet and inlet? When I bought mine it did not matter where the inlet or outlet line connected to.
Does this depend on the cooler used?
Old Jan 8, 2005 | 07:57 PM
IROCaholic's Avatar
Car: 89 Camaro RS
I dont know, thats just what my instructions said to do.
Old Jan 8, 2005 | 08:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Plug the holes? So you replaced the factory cooler with the aftermarket one? What brand and model is it?
Old Jan 8, 2005 | 09:10 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Yeah I added an aftermarket one. I dont know what brand becuase Ive had it for months and I threw the box away a while ago. I got it at Orieleys auto parts off of the shelf.
Old Jan 9, 2005 | 12:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
How much hotter is the coolant?
Old Jan 9, 2005 | 12:47 AM
IROCaholic's Avatar
Car: 89 Camaro RS
I guess I should say gets hot quicker because normally after cruising around for 10mins or so the engine temp will get up to about 210 and stay there. And once I hit traffic and have to stop and go alot it will be at around 220. But earlier it got up to 220 after cruising at a constant speed for about 10mins which is usaully the time I have the best cooling.
Old Jan 9, 2005 | 02:18 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Were you expecting the transmission cooler to reduce your engine temperature? If your engine is running hot (sounds like it is), then your factory cooler could have been lowering your engine temperatures by allowing for the transfer of heat from the coolant to the transmission fluid.
Old Jan 9, 2005 | 11:36 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
84z96L31vortec
Aug 20, 2017 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
