car wont start...seems like battery is dead but its not
Old Jun 29, 2001 | 03:31 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
the other day i went to start my car, and it was as if the battery was dead. it turned over for a second then just clicked. so, i got my other car and tried to jump it and the same thing happened. then i tried to charge it and the same thing happened again.
like i said, its like the battery just isnt strong enough to turn the starter so it just clicks way like it was dead. and either its a new battery. and, even when i jump it with my other car OR charge it, nothing happens any different. once i saw that, i ruled out the charging/battery system, because even with a known good battery,it didnt work. then i though it had to be the starter.
i took it out and brought the starter to NAPA because it has a lifetime warranty, so i figured they would just give me a new one and it would fix the problem. they tested it and it was "good" so they say, so they woudnt give me another one. so i put it back in.
i have checked everything, but i cant find the problem.
by the way..once in a while (like onece every 30 tries) the car just starts right up like there was no problem at all. cranks strong, turns right over, and fires.
any ideas? need any more info? just reply and i will tell you anything you need to know. thanks a lot.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
10 bolt - SLP zexel torsen differential, GM 3.42s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
Old Jun 29, 2001 | 03:40 PM
Gta-Paladin's Avatar
Sounds like the Starter to me... could be the alternator though, good luck.
Old Jun 29, 2001 | 03:46 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
yeah, but correct me if i am wrong...the alternator will only cause problems once the engine is running? could the alternator be causing the problem, since it is theoretically not involved with starting the car?
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Jun 29, 2001 | 04:58 PM
You might not have enough cca to turn the engine over because the alternator hasnt been charging recently
Old Jun 29, 2001 | 05:27 PM
Drakar's Avatar
I had what I think it the same problem in my 92 RS, some guys tried to rip it off but the VATS foiled the Screw driver , but in the process the cracked a rod in the steering column, it worth a look at.
1989 GTA 350 TPI - T-tops, dual cats, 9-Bolt aussie 3.27
1992 RS 305 TBI - T-tops, T-5, 3.08 - Sold
Old Jun 29, 2001 | 09:02 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Have you checked your batt. to block ground?
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Jun 29, 2001 | 09:03 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
yeah its fine
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Jun 29, 2001 | 10:08 PM
302GT_killer's Avatar
did you check your fusible link?
Old Jun 29, 2001 | 10:50 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Go through and reclean the battery terminals on the battery, starter and block/alt bracket, wherever it goes to,,sure sounds like a bad ground.
ANy corrosion in the battery cables, just past the connectors? Look for some white stuff in there, if you see any, get new cables.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
justin57
Aug 20, 2015 07:05 PM
hokis
Aug 9, 2015 03:57 PM
