Shaking Steering Wheel/Front End(?)
Old Jul 4, 2001 | 10:34 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
As if i dont have enough to work on with this car already, now this. At speeds between 65mph and 73mph, my steering wheel shakes up and down....doesnt do it at lower speeds, and i dont think it does it at higher speeds either. If i hold the wheel tight enough for the wheel not to shake, then i feel the front end under the car shaking as well. My dad and his mechanic had recently checked out the tire rods(this was a few months ago not for this reason) and they are nice and tight and fine. A friend of mine suggested the idler arm....any other suggestions/ideas?
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old Jul 4, 2001 | 10:50 PM
rezinn's Avatar
Did you have the tie rods checked? Does it happen at 74mph? Is the driveshaft balanced?
Old Jul 4, 2001 | 10:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Triangular (separated) tires? more common than you might think.
ICON Motorsports
Old Jul 5, 2001 | 07:45 AM
82camaro's Avatar
Car: 82 camaro SC
bad balance
bad tire/tires
bad wheel/wheels
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 5, 2001 | 03:33 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Rezinn....
Tire rods have been checked out...they are nice and tight. Driveshaft hasnt been touched, didnt check that. Has to be looked into.
RB83L69....
Triangular(seperated) tires?? What the h-ll is that??
82 Camaro....
Tires are good....almost new. Wheels are fine. Probably balance is the only other thing i can think of....
Oustside of that, what about the idler arm??
OTHER RIDE:
12/14 Options
Stock(for now)
Old Jul 5, 2001 | 04:53 PM
rezinn's Avatar
Check if I am correct, but I think if the idler arm was screwed up, you would have problems at more than just a certain speed range. I would definately have the driveshaft balanced and replace the u-joints. Sorry you didn't get my joke about "tie rods" =p
Old Jul 5, 2001 | 05:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I jokingly referred to yerbasic typical separated tire as "triangular", since it's usually even worse than how it would be if it was "square". Even new tires (especially can be separated. I've seen that happen more than once. It occurs when the belts don't adhere to each other and the tire gets a lump in it somewhere. You can park the car and run your hands around them and feel them, usually. More often than not they're at one edge of the tread, so the tread will feel uneven from one edge to the other for some distance around the tire.
ICON Motorsports
Old Jul 5, 2001 | 09:25 PM
irocbsa's Avatar
A bad idler arm would cause the shaking at all speeds. I had a bad idler arm and the shaking only occured at lower speeds. On the highway it was fine. Its happening again though so it looks like I need to replace the Pitman arm and centerlink as well.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 6, 2001 | 12:23 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
Rezinn & RB83...
Sorry guys, for not picking up on that....i must not have been all there when you guys made those jokes....i'm still recovering from the 4th Anyway, i guess i will just have to do a sweep of the front end, including the tires, and go piece by piece. This shaking has got to stop, its verry annoying, especially when you have a chick in the car with you, and she looks over, and you look like you are holding onto a jackhammer while trying to smile at her....not a big turn on, i dont think.
Thanks for the help guys.
OTHER RIDE:
12/14 Options
Stock(for now)
deracer
Apr 11, 2016 12:04 AM
xxx3man`
Sep 23, 2015 10:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Bull86
Aug 10, 2015 05:43 PM
