engine combo question
Old Mar 12, 2005 | 08:35 PM
Dioak88GTA's Avatar
Car: 88 Trans Am GTA
Engine: 5.0 TPI
Transmission: 700R-4
just want to know what you guys think this setup i already have half invested in will run...1/4 mile times
350 bored .030
dart iron eagles 64 cc combustion chamber 180 cc intake runner
230 int./236 exh. @ 050 lift duration
.487 int./.490 exh. lift w/ 1.5 rocker arms (running 1.6)
edelbrock air gap intake
holley 750 double pumper
lightweight flexplate
2400 stall
stock suspension for an 88 gta
275 mm wide drag radials
Old Mar 12, 2005 | 08:39 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Sounds exactly what i would run for an all-around street car,except the drap radials.
Old Mar 14, 2005 | 12:22 PM
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
anybody else?
Old Mar 14, 2005 | 01:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sure a 750dp is a good idea? A 650 might work better for your combo, especially with an automatic.
Old Mar 14, 2005 | 09:39 PM
Dioak88GTA's Avatar
Engine: 5.0 TPI
with the flow a 750 wouldn't be too big at all. a 650 would be too small, i don't however need the double pumper, i just have it laying around
Old Mar 14, 2005 | 09:43 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
I have an engine very similar, with a little more cam and pat musi ported torquer heads. I took off my 650dp and strapped on an 850dp. After a few days of tuning, I had acceptable throttle response and maybe 40 more horses top end. Depends on what you want, throttle response, 650, ***** to the wall power, 750 or 850.
Old Mar 14, 2005 | 11:30 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
seems to me that you could find a cam with the same duration and a little more lift.
for example
comp cams XE282HR
230/236 .510/.520
this is what i would use
Old Mar 15, 2005 | 01:05 PM
Dioak88GTA's Avatar
Engine: 5.0 TPI
i was thinking a little more duration and lift myself, but i called up comp cams, let them know my setup and they recommended that one...
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
