Windshield washer push lever
Old Jul 13, 2001 | 09:06 PM
NHcamaro's Avatar
The lever that you push to wash the windshield with was broken when I got my car and now I want to fix it. How do I go about doing this. Taking it apart etc.
1988 Sport Coupe 305 TBI
K&N
Flowmaster exhaust
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
Old Jul 13, 2001 | 09:25 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
take off the steering wheel, you will need a puller, keep tearing it down until you're at the lever, remove and replace, reassemble in the reverse order..
Webmaster: www.IROC-Z.org
Old Jul 13, 2001 | 09:28 PM
NHcamaro's Avatar
whats a puller?
Old Jul 13, 2001 | 09:33 PM
Engine: 305TPI
the puller looks like a Y, you can rent it at AutoZone..
you put 3 bolts into the steering wheel and then use a large bolt in the center to pull the wheel off.. you tighten the center bolt and it'll slowly pull the wheel off and it'll fall into your hands..
Old Jul 13, 2001 | 09:35 PM
NHcamaro's Avatar
wow. seems like alot of work just to get that stupid thing off lol.
Old Jul 13, 2001 | 09:36 PM
Engine: 305TPI
heh..
it shouldn't take you more than 15 minutes to get it off..
i changed the camber switch in my old truck in like 25 minutes, lol..
Old Jul 14, 2001 | 12:27 AM
iroc5speed's Avatar
I would try to take off the steeering wheel without even using the puller. I've taken 2 off recently and they just came right off, no force needed.
Old Jul 15, 2001 | 02:55 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Whoa whoa whoa are you just talking about the plastic part of the lever that it's cracked in half? Just pull out the lever and the part that engages the switch (that they're talking about inside the column) is a little tab that fits into the circular switch. You can drill a small screw into this tab or something, or you might try reparing the plastic with a heat gun or something.
Old Jul 15, 2001 | 09:00 AM
NHcamaro's Avatar
yeah thats the one I ROCK sorry I wasn't more detail in my question
Old Jul 16, 2001 | 04:24 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Just as long as you know that you DON'T need to tear into the column...
Old Jul 16, 2001 | 04:57 PM
NHcamaro's Avatar
LoL big check on that one
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
tattmann
Sep 27, 2015 05:20 PM
