Changing Valve Spring
Old Mar 18, 2005 | 12:49 PM
BlackMagic's Avatar
Car: 1986 Firebird
I am still new when it comes to get hands down in grease and oil, so help me out some. I am replacing a spring that busted on my 350 TPI and need to know what i need to cahnge the springs? Any help and advice would be greatly apreciated.
Old Mar 18, 2005 | 12:58 PM
F-BirdBauman's Avatar
Car: 1987 Firebird
Engine: D.Remmington 415 Small Block
Axle/Gears: 4.10
a valve spring compressor and a set of sae sockets and a rachet to fit the sockets,and a set of allen wrences.
1) remove valve cover with the coresponding allen wrench.
2)Remove Rocker arm.
3)compress valve spring using the spring compressor.
4)remove spring retainer locks.
5)remove spring.
reassembly is as order reversed but compress spring befor reinstalling retainer locks.
Old Mar 18, 2005 | 01:03 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I have a valve spring compressor from sears, I think it was about $15.
There are a few different types of spring compressors. Some work with the heads still mounted on the engine, and others you have to have the heads removed.
Do some shopping... or maybe someone will post pics of the type you need.
Old Mar 18, 2005 | 01:06 PM
BlackMagic's Avatar
Car: 1986 Firebird
yeah i would love to get some that would allow me to take the spring off while the heads are still on. I am hoping to get this done tomorow so that i can go to the track tomorow.
BlackMagic's Avatar
Car: 1986 Firebird
Old Mar 18, 2005 | 01:12 PM
Car: '85 IROC
Engine: LB9
If you have a deadline, just go to the parts store (or sears) and ask for a spring compressor that can be used without removing the heads.
Practice on a scrap head a few times til you feel good about it... Then go for it.
Oh and be sure the valve doesn't fall down into the cyl when you remove the keepers.
There's a special trick to that. I'll let someone else explain. I'm late for work.
Old Mar 18, 2005 | 01:13 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The cheap one from sears looks like a handle, with a hole in it for mounting on the rocker stud. It works fine, but you need to remove the spark plug and fill the cylinder with compressed air to remove the spring. A hose from a compression tester kit works great. Be sure and remove the check valve in the hose before installing it.
Are the springs real old? If so I hope you are planning on replacing them all, not just the one that broke.
Old Mar 18, 2005 | 10:20 PM
BlackMagic's Avatar
Car: 1986 Firebird
yes the springs are all old, maybe even factory, and yes i am only replcing the one, but hear me out! LOL...i have a 350 TPI i am building and this one wont be in to much longer, so this is just a quick fix to stretch it alittle longer till i get finished with the 350
Old Mar 18, 2005 | 11:27 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
$15 Sears jobber:
You need an adapter for an air line and a source of air to keep the valve up and make everything easier.
IIRC 86 doesn't have centerbolt heads so you need the appropriate socket to remove your v/c bolts.
Do you know why it broke yet? That is the important question here.
Old Mar 19, 2005 | 12:01 AM
91Z28-350's Avatar
Use some rope if you don't have an air compressor.
The $15 spring compressor sucks, btw, but it'll get the job done...slowly. Wear eye protection with that compressor, the springs can pop out.
Before you compress the spring, bang straight down on the spring (lightly) with a socket and a rubber mallot to break the keepers from the retainer. It tends to stick over time and needs help coming free.
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
