Rotten Egg smell
Old Mar 23, 2005 | 08:14 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Rotten Egg smell
Some times when i turn my car on it smells like rotten egg and blue and sometimes black smoke comes out... what could this mean? dirty fuel injectors?
Old Mar 23, 2005 | 08:17 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Sulphur in the gas. Common problem.
If you aren't running cat(s), it is far worse.
Old Mar 23, 2005 | 08:18 PM
Engine: SBC, LS-x
The blue smoke on startup is likely oil getting into the combustion chambers via the valve guides. New valve guide seals will fix that up if it bothers you.
Old Mar 23, 2005 | 08:22 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
How can I correct this?
Old Mar 23, 2005 | 08:53 PM
Engine: SBC, LS-x
Different brand of gas. Some have much higher sulphur content than others.
Are you running a cat(s)?
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
try a different brand of gas.
Old Mar 24, 2005 | 12:49 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
By Cats do you mean catylin converters?
Old Mar 24, 2005 | 12:51 AM
Engine: SBC, LS-x
Yes.
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
