Major Problem
Old Mar 24, 2005 | 10:59 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
Major Problem
sorry its so long
ok here it is..this has happend once in a million times to me but when slowing down and then slowly accelerating again it just feels like the car is trying to shut off and there is a tapping and clicking i can feel on the pedal also like the gas is cutting out. On the way home from school yesterday i was slowing down around some curved and when i started to accelerate again the clicking started but this time click click click...died and the steering wheel locked up going about 20 mph. If it was the fuel pump it wouldnt just lock up the steering wheel would it?? Ok started up just fine but smelled something burning...not sure what it was. After words i went to the gas station and threw in some good ole premium. When i was on my way to school it started clicking again going around a corner but didnt die. After school i decided to go get an oil change because it had been a while and i didnt have the time to change it before i went to FL... started to really heat up waiting to pull in. While i was on my way home...going around a corner it threw an SES light. when i got home and turned it off then back on..light dissapeared. After work, it was raining and i decided to spin them a little so i did a lil brake stand..murder on brakes i know.. but when i reved it to about 2 the car just flat out died. When pulling into the garage i heard a thunk thunk when i was tapping the brakes to get in. There are a few problems that i know of..
*Power Steering leak from the hose
*Cracked but not broke belt
*Possible Broken Tranny Mount
Edit- Was running regular gasw when it first started
Old Mar 24, 2005 | 11:18 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Did you try pulling any codes?
Old Mar 24, 2005 | 11:31 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
just ran them and got a
43. Low voltage at electronic spark timing circuit
Not too sure on what this means...any suggestions?? Dizzy Cap??
Maybe ECM??? Coil??
Old Mar 25, 2005 | 06:25 AM
ede's Avatar
ede
just guessing by how the letters and numbers are arranged i'd think it means you have a low voltage problem to the EST. you could try random parts replacement or trouble shooting. either would work. trouble shooting might be a bit quicker and cheaper.
Old Mar 25, 2005 | 08:12 AM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
What exactly is the EST and how should i go about troubleshooting this??
Old Mar 25, 2005 | 10:01 AM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
ok read another post and found a little information.
Code 43= Electronic spark control. Caused by; Poor electrical connection,open or short in circuit,defective ESC module,or knock sensor,defective ECM
What would be the first thing to check...the sensor??
Could the poor electrical connection be from a weak battery?
code 43 also...
not enough voltage from battery??
running neons, amp, and fog lights, radar, and laptop
thinking of any possible cause before i just start buyin parts that dont fix the problem
Old Mar 25, 2005 | 08:12 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
I WOULD CHECK OUT THE IGNITION SWITCH, YOUR WHEEL SHOULD NOT LOCK UNLESS YOU TURN THE IGNITION TO THE LOCK POSITION. THE IGNITION SWITCH CAN ALSO CAUSE THE CAR TO DIE. DO YOU HAVE A BRICK ON YOUR KEY CHAIN?
Old Mar 25, 2005 | 08:38 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
recently replaced the igniton switch. Wheel didnt lock just power steering shut off sorry bout that. Only kicks off like that when its cold...when its idling the temerature really raises to about 240 with a 160 degree stat installed. when SES light comes on the car greatly reduces power..basically telling me the timing retards. Maybe knock sensor?? or maybe the ECM. When holding brake and just tapping gas the car just dies. Could the clicking i hear be the fuel pump comming in and out??
Old Mar 25, 2005 | 08:47 PM
Car: 92'Camaro RS
Engine: a loud one
I would also check your connections at the dizzy. There should be two different pigtails at the back of your dizzy, make sure you have a good connection.The one should have like four wires in one plug and i think,two in the other. I was getting the same code before also.I ended up replacing one of the pig tails and throwing in a MSD box in and it solved my problem.
Old Mar 25, 2005 | 08:55 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
ill check into that as soon as i can thanks for all your help i will be posting the results as soon as i get a chance
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
mrdevontay
Sep 2, 2015 08:04 PM
greenyone
Sep 2, 2015 03:39 PM
