Hose to windshied washer pump?
Old Jul 22, 2001 | 10:58 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
My windshield washers haven't been working, and then I noticed that the hose coming from the tank was just laying inside the engine compartment (no clue on why it wasn't connected up). I've searched in there and I just can't seem to find where the hose hooks up to the pump. Where is that inlet located?
Old Jul 22, 2001 | 11:07 PM
rezinn's Avatar
The hose from the cap of the tank goes to the outside nipple on the pump. It should be mounted on the back of the engine bay just under the drivers side wiper.. there should also be a hose going into the wall from the rear of the pump.
Old Jul 22, 2001 | 11:10 PM
un4givin89's Avatar
humm, mine don't work either, I'm gonna go look at mine, wonder if mine is still conected and if the pump works.
Old Jul 22, 2001 | 11:53 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
the nipple rezin is talking about is hard to find. The pump motor is in the bottom of the wiper motor, and is hidden in a cylinder about 2in. long and about an in. wide or so. Maybe that helps.
Old Jul 23, 2001 | 12:01 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Thanks for the replies; I'll have to take a look tomorrow. I'll let you know how it goes.
Old Jul 23, 2001 | 02:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I found my hose like that too and it turned out the nipple on the pump had broken off inside the hose.
Old Jul 23, 2001 | 02:33 AM
Blue_Meanie86SC's Avatar
the pump is on the passanger end of the wiper motor assembly (located on the drivers side of the firewall) if you have trouble locating it, turn on your wipers, you'll hear it and see movement. But yeah, the hose attaches on the bottom, follow the hoses that run to the nozels backwards to find it.
Old Jul 24, 2001 | 11:45 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Just checked my windshield washer hose, turns out the nipple broke off inside it... guess I need a new pump now.
Old Jul 25, 2001 | 10:39 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Replaced the pump... had to prime it a bit with some water, but it works now.
Old Jan 18, 2008 | 06:25 PM
kabal's Avatar
Re: Hose to windshied washer pump?
as i put on the new pump for my windshiels motor after i had put both rubber hoses back on i broke the tip for the second hoses on the new pump where does the rubber hoses go to the first hoses is attach to the lines which runs in the nipple spikit where does the other hose connect to , does it go to the firre wall or else where , like under the the unit it self i have a camaro 5.0 z 28 1986
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Randomtask2
Aug 26, 2015 03:34 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
