Why did that truck out run me?????
Old Apr 7, 2005 | 10:34 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
OK, on the way home tonight my buddy (who has a 91 4-wheel drive Chevy 1500) passes me. So I tried to pull around him. Now, he just put a 350 in to replace the factoy 4.3. Sad thing is, I not only didn't pull around him, but he might have been able to leave me in a longer straight. I think (in fact, I know) that the tune up made my car worse. Is this possible? And how can I get back my bragging rights????? Thanks.
Old Apr 8, 2005 | 09:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
L03
350
Hmmm..... I'm just searching for clues here.... I'll get back to you on that.
Old Apr 8, 2005 | 07:14 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Well if your stock you have 170 hp. If he is stock his 350 probably has @ 225. He is carrying a little more weight.
Have you beat him before?
What did you do on the tune up? Change timing?
Old Apr 8, 2005 | 07:16 PM
azvolfan's Avatar
Oh and if his 350 is newer than his '91 truck, he probably has more horsepower than 225.
Old Apr 9, 2005 | 08:51 PM
chevydude350ho's Avatar
Car: 90 Iroc-Z
Engine: carb'd 350
Transmission: built 700r4/3000 stall
Somethings wrong, because my buddys 90 2wd longbox ran 16.7 bone stock. So yeah....
Old Apr 9, 2005 | 10:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My buddys bone stock L03 1992 RS ran a 17.8 which would explain why you got beat. My G20 would more than likely would hand it, to you too.
Old Apr 9, 2005 | 11:06 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Ouch. Now I am afraid to see what my very mild lg4 will do... I bet my '87 2.8 5 speed would be just as fast, if the clutch wasnt slipping...
Old Apr 10, 2005 | 12:49 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
You should have beat him. What did you do during your tune up?
Old Apr 10, 2005 | 09:16 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I had the guy do plugs, plug wires, timing and he changed the distributer.... used a used one. He also used cheap wires. I think the timing is more off now than before. I wonder if a 91 RS 5-speed with a L98 B2L 5.7 Liter TPI from an 90 I-ROC would beat it?
Old Apr 10, 2005 | 09:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
would beat it
Looks like it would.
Probably would win a race against it, too.
Old Apr 10, 2005 | 11:10 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Your search is over. I found your problem.
Seriously, why would you wonder whats wrong if you know the timing is off. Go buy a timing light, and set it to 6 degrees BTDC with the tan wire disconnected by the passenger side strut tower.
Old Apr 10, 2005 | 12:44 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
What is a BTDC? Where can I get a timing light? I'll go look for the tan wire now. Thanks. I was thinking I was going to have to have a mechanic do it.
Old Apr 10, 2005 | 04:41 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
A few side notes here, 4.3L full size trucks came with a few different gear options 3.73's are most common but you will find some with 4.10's from the factory as part of a tow package. Seems stupid to me to have that option on a 4.3L a 350 would be all the tow package you need. I had one setup with a TP swaped in a 305 kept it TBI, the truck ran awsome too bad my ex has it now.
3.42's a full EXH system and you should be able to take that truck.
Old Apr 10, 2005 | 04:48 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I plan to buy another car anyway. It is on sale in the for sale section. The RS 5.7 TPI 5-speed with the 3.27 pos rear end. His truck is a 5-speed and it has the 4.10 because it was a 4.3 before. He decided to V-8 it a couple of weeks ago.
BTW, how do you like your headers? And how much were they?
Old Apr 10, 2005 | 09:40 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Quite a few people have been assuming that you have an L03 due to your sig, and you fail to mention its a tuned port 350 after all this time?
Old Apr 10, 2005 | 09:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I think he is going to buy an L98 car in place of his current LO3.
Old Apr 10, 2005 | 09:47 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
No, that is the car I am looking to buy. Mine is and L03 w/ 700r4.
Old Apr 10, 2005 | 09:49 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Yeah, what he said. That would have been a scary truck if mine were a TPI 350, huh?
Old Apr 10, 2005 | 11:04 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Sorry, I misread your post.
Old Apr 11, 2005 | 01:17 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
No problem.
Old Apr 11, 2005 | 10:25 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That would be a truck with the same engine as my G20. LOL.
Old Apr 11, 2005 | 11:33 PM
Car: 90 Iroc-Z
Engine: carb'd 350
Not all 4.3s came with low gears. My '89 came with a 5spd and 3.08s. Got great mileage, but not much in the power department. Switched to 4.10s and what a difference. Beats most 350 trucks pretty good now.
Old Apr 12, 2005 | 01:41 AM
SchwarzCamaroRS's Avatar
lol, thats why... 305cid in your car, 350 cid in his... after i did the 350 swap in my car and changed out the rearend, it got FAST, so i understand your loss... but ive seen LO3's whup up on some 350's though
Old Apr 12, 2005 | 02:42 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I got the timing set today. That should help next time. It turns out the 350 he put in is an Intercepter (at least the manifold and heads). That could explain it to a degree..... I was thinking about putting a 3.40 or so in the one I hope to get. It is a 350 5-speed. It now has the 3.27 pos.
Old Apr 12, 2005 | 02:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Intercepter
Buzzword with no relationship to any parts
Old Apr 12, 2005 | 04:51 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Oh. I thought that it was a performance package. Like the one for Camaros.
Old Apr 12, 2005 | 05:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There wasn't a "performance package" for the Camaro police cars either. They came with the same engine as any other equivalently optioned 305 or 350. Nothing special.
Don't get sucked in by buzzwords.... or next thing you know, somebody will have you paying extra for their "Vortec rocker arms" or "375 HP 327 cam" or something else worthless and undistinguished like that.
Old Apr 12, 2005 | 05:28 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I won't. I ussually do alot of research b4 I buy anything personally. What do you think about aftermarket vortec heads on a third gen? I was thinking about it. They aren't terribly expensive and make pretty good power.
Old Apr 13, 2005 | 10:43 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Been slam'd at work lately.
There ok, better then stock manifolds. I got them a few years ago for the bird, I think they were $80. They Y pipe is the expensive piece if you were to use the FT Y it's around $130 just for it, I had my Y's custom made.
jhawkeye
May 25, 2022 06:33 PM
nuggie
Aug 25, 2015 01:27 PM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 13, 2015 07:35 AM
squiggy2
Aug 9, 2015 09:30 PM
