Car dies at full throttle!! Help!!!!
Old May 4, 2005 | 07:28 PM
jeffsbluez's Avatar
Car: 91 z28
Car drives fine but when I go to full throttle check engine light comes on and motor dies. When I let out of the throttle a little, car stats to run again! Help. Could it be a bad TPS sensor?
Thanks!
Old May 4, 2005 | 07:53 PM
jeffsbluez's Avatar
Car: 91 z28
anyone?
Old May 9, 2005 | 10:28 PM
jeffsbluez's Avatar
Car: 91 z28
Please.... Anyone????
Old May 9, 2005 | 10:35 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Have ya thought about maybe pulling the codes?
Old May 9, 2005 | 10:37 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Dying with throttle could mean you're running far too lean. Check for vacuum leaks. Also, what's the condition of your fuel filter?
Old May 10, 2005 | 05:21 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Fuel filter.....
Old May 11, 2005 | 08:52 PM
jeffsbluez's Avatar
Car: 91 z28
No code showing. Just put in a new fuel filter. 13.2 A/F ratio. Anyne else??? Thank you all for you responces!!!
Old May 12, 2005 | 11:46 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Are you running a WBo2? If so, does it go lean or rich when eng dies?
Can you datalog while it's happening?
Old May 12, 2005 | 05:30 PM
jeffsbluez's Avatar
Car: 91 z28
Put on a new TPS and my car is running fine. Thank you to all who repied!! Keep'em on Three! lol
Jeff
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
novaderrik
Aug 10, 2015 12:44 PM
