Rotten Egg Smell!!!
Old May 11, 2005 | 04:59 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Rotten Egg Smell!!!
This smell is nasty YO!!! I can smell it when i first turn on my car which is cold and only on the weekends (not a daily driver) and after i stop somewhere and i go to start it again i get that smell in the vents only for a couple of seconds. Brand new Cat, just pasted smog with flying colors too.. I put the best gas which is Cheveron (Premium)... Any Ideas???
Old May 11, 2005 | 05:32 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
its the new cat they all do that. in time it will go away. take the car on a nice long highway run to get it real hot that will speed the process.
jeff
Old May 11, 2005 | 05:48 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
How's your timing? Try using a lower octane fuel or even a different brand- it sounds like poor combustion. Also, what's the condition of your catalytic converter?
btw, anything above 91 is un-necessary on these cars. The compression ratio for an LO3 is 9.3:1, and I've never had problems using 87 and even 86 octane in it.
Old May 11, 2005 | 06:11 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
My timming is at 0 but im going to put it at 6* cause it likes it there. Then i have to use the High Octane cause it will ping. But I never had the problem of that smell till the new cat came on. I ll just take it out for awhile and get it nice and hot.
Old May 11, 2005 | 06:16 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
hmm, new cat I didn't read that. that's probably it. But also, the brand of gasoline can definitely have an affect.
Old May 11, 2005 | 06:53 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Do you think too that my O2 is acting up? Its about a year old and its a stupid BOSH!!! Could it be that im running rich too. I also noticed that at WOT i can smell it too. I probaly have an Exhaust leak. The bolts I use to hold the Headers in suck grass!! Ill change to different gas
Old May 11, 2005 | 07:01 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I was going to suggest that, but I assumed you were properly tuned up. You acted like it was directly related to the cat so I didn't know
But still, running leaner will help heat that cat up faster.
Old May 11, 2005 | 08:54 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
you think i should go ahead and change out the O2 for a AC Delco one?
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
