2-bolt Main To 4-bolt Main Caps?
Old May 24, 2005 | 10:35 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
I was looking around the internet and ebay , and found that there are kits to convert your 2 bolt to a 4 bolt and it would be stronger than a stock 4 bolt main.
my question is, is it worth it? and how mouch would it cost to do this?
thanks!
Old May 24, 2005 | 10:37 PM
3rd gen V8's Avatar
And oh, I was not thinking about doing this to my 305 .
Old May 24, 2005 | 11:59 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Unless you want to go over 500hp on an otherwise stock block, you probably don't need it.
Old May 25, 2005 | 12:01 AM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
you stole the words right out of my chomper!
Old May 25, 2005 | 12:02 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
a 4bolt main is prolly way more then your going to need
and yeah you could prolly do it on your own but I would also be leary about it just because knowing my lcuk I would get too close tosomethig I shouldn't and make it weaker
Old May 25, 2005 | 12:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not unless you can mill the block, drill and tap the holes and align bore the new caps in your garage.
Old May 25, 2005 | 01:13 AM
EvilCartman's Avatar
Car: '82 Z28
I'm still running a 2-bolt main well, not actually bolts anymore, ARP main stud kit.
Old May 25, 2005 | 02:19 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
eh I don't have the tools off hand for that way
do you think jb weld, duct tape and some coat hangers would work?
Old May 25, 2005 | 06:42 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
only if you have a big enough hammer.
Old May 25, 2005 | 08:22 AM
3rd gen V8's Avatar
So a two bolt main is still preaty beefy then. but i was hopeing to be in the 480 ish to 500 horse power range. on a built 350 2-bolt main with out some thing breaking on me.
Old May 25, 2005 | 08:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes those "kits" make a block stronger than a factory 4-bolt main, by far. Factory 4-bolts aren't meant for racing. They are ineffective against that kind of stress. They're really meant for truck motors.... high load on the motor continuously, moderate RPMs.
If you're serious about the 500 HP business and it's not just a bunch of spank-off, and you want to strengthen your block, I would not recommend getting the cheap chinesium ones off of ebay. There are several USA mfrs that make a much more dependable product. For example http://store.summitracing.com/partde...rt=MIL%2D11150 Here's another thing that DRAMATICALLY stabilizes a stock block for racing type usage. http://store.summitracing.com/partde...t=HNH%2D860212
Old May 25, 2005 | 05:32 PM
3rd gen V8's Avatar
thanks for the links! and thanks for your guys comments.
6speedIROC
16
Mar 15, 2023 08:33 PM
Stryker412
Sep 20, 2015 06:59 PM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
TBRays98
Sep 6, 2015 05:05 PM
