How much hp does my car really have??
Old Aug 27, 2001 | 11:21 PM
Trent257's Avatar
ok, the main site says its got 170hp, but i just raced a 190hp toyota camery, and totaly wasted him, is there like a pontiac historical site er something??
Trent
---Car---
89 Firebird
305 L03 TBI A4
t-tops
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's
Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
2 pioneer 12" ts-w303c subs (selling if anyone wants em email me)
Future:im profile 1200sx 900watt x 1, and a pioneer cdx-p1270 12 disk cd changer
Old Aug 27, 2001 | 11:37 PM
tacoboy's Avatar
how bout accounting for torque too?
Old Aug 27, 2001 | 11:40 PM
Trent257's Avatar
his cars rated at 215, mines 255
but would make that much of a difference, i mean we doth got off the line at the same time, and i had my ttops of, which is a major drag, but i really wasted him, i mean badd
Trent
---Car---
89 Firebird
305 L03 TBI A4
t-tops
---Stero---
profile cl640 110x4
Old Aug 28, 2001 | 12:09 AM
rezinn's Avatar
Horsepower ratings aren't really a great indication of how fast a car is. A lot of other things factor in, just like drag. If you could see a dyno sheet you could tell how flat your horsepower and torque curves are, compared to his.. Just because his peak horsepower is higher than yours doesn't mean that your average horsepower throughout your rpm range isn't higher than his.. you see what I mean? The extra torque can help a lot too, thats something that imports have trouble making up for.
Old Aug 28, 2001 | 03:18 AM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
The figure "horsepower" is really derived from the engine's torque output through the formula:
Torque * RPM
Horsepower = -------------
5252
This goes to show that torque is more important than horsepower... the fact that you are winning because of higher torque even though peak horspower is lower.
However, there are plenty of other factors that influence the winner of the race anyway.... broader hp/torque curves, gears, etc.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Aug 28, 2001 | 05:58 AM
Trent257's Avatar
ok thanks for explainng to me
Trent
---Car---
89 Firebird
305 L03 TBI A4
t-tops
---Stero---
profile cl640 110x4
Old Aug 28, 2001 | 08:48 AM
85transamtpi's Avatar
Yes, your car is rated at around 170hp, and Yes you will probably win every race against that car. Those rice engines are pretty weak in real world driving, even though they may be rated at a higher horsepower than you are. For instance the honda s2000 makes 240 horsepower, but only has around 180 ft/lbs of torque at an insane rpm. If you drive those things (and I have) and shift at like a still screaming 7000rpm its slow as ****. In order for it to make its power it has to hit like 8-9k...sounds good on paper, but in real world driving feels almost underpowered.
Keep killin the rice every time you get a chance
peace
Old Aug 28, 2001 | 09:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
85 and others explained it pretty well...
HP is the product of torque times RPM. The thing that actually speeds up the car is torque. To get a high HP number you could have a relatively high torque at a relatively low RPM, or moderate torque at a ver high RPM, or some other similar combination. Also keep in mind that those are peak HP ratings; if there's not much at jsut a few RPMs below that peak and a few above it, then it doesn't really matter what the peak value is, because the engine spends so little of its time there.
I don't really care what kind of magic numbers those guys can miracle up and print on their glossy ads and get yuppies to fall for. In the real world, power comes from burning gasoline, efficiently; once you achieve a certain level of efficiency, if you want to get more power, you have to burn more gasoline; burning gasoline requires air; air requires space, and flow. There's the keys to power: displacement, and flow. If you're missing either one, someone with more of it will stomp you.
ICON Motorsports
Old Aug 28, 2001 | 10:55 AM
rduskin's Avatar
I also have a L03 TBI in my 90 Firebird. For the past 2 years that I have owned it, I thought it was a formula. But according to this site, I guess it's not. But it does haul butt.
Old Aug 29, 2001 | 01:07 AM
Laymaster's Avatar
I dont' get how torque is soooo much more important than horsepower. If that's so, how come some diesel mack trucks wouldn't kick some major *** . I mean, they have like 400 torque at 1400 RPM or something.
Old Aug 29, 2001 | 02:21 AM
EvilCartman's Avatar
Car: '82 Z28
They're made to pull heavy loads not drag race
Just remembered a page that explains it a bit... http://www.dynacam.com/Product/Torqu...orsepower.html
'82 Z28
LG4 305 .030 over, performer intake, holley street avenger 670, xe 256 cam, tes headers, 3 inch single exhaust, spintech muffler, 14 x 3 inch drop base k&n.
[This message has been edited by EvilCartman (edited August 29, 2001).]
Old Aug 29, 2001 | 08:56 AM
Z28DJP1987's Avatar
Don't forget your sound system is also blasting you along faster.
Old Aug 30, 2001 | 08:21 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I had my L03 Camaro on a dyno two weeks ago getting a base line for future mods.
155 rwhp & 241 rwtorque
182 hp & 284 torque with 18% adjustment for the driveline.
The only mods are a Hooker cat-back, Edelbrock water pump, K&N filter and 180 degree thermostat. L03's torque spikes up at a very low RPM (2400) and stays fairly level until it tops 4000 and the drops like a rock.
Bill Rockhold
92 Camaro RS, 305 TBI M5 F41
SCCA Solo2
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
