406 oil pan problems
Old Jun 26, 2005 | 07:00 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I am nearing the nd of my 406 SBC project, and I have encountered an unexpected problem. The oil pan does not appear to be in contact with the molded pan gasket at the front adjacent to the timing cover. Can anyone answer this problem?
I am using Milodon oil pan 30700
Fel-Pro molded one piece gasket 1885
and GM timing cover 10243967
Thanks, Andy
Old Jun 26, 2005 | 08:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The Fel-Pro 1885 is for pans using the thin front seal. You probably need a Fel-Pro 1880 for the thick front seal pan.
Old Jul 8, 2005 | 08:06 PM
ANDYZ28's Avatar
Car: 1982 Z-28
You are correct, the 1880 did the trick. It fit perfectly!
I wonder what applications the 1885 fits? Thick vs thin front seal?
Old Jul 8, 2005 | 08:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The thickness of the front seal is the only difference. I don't know what the difference in application was between the two.
Old Jul 10, 2005 | 06:20 AM
ANDYZ28's Avatar
Car: 1982 Z-28
I can't imagine an application that would use the thin front seal gasket. But I will try to find out and post the info.
Old Jul 10, 2005 | 11:49 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Most aftermarket pans use the thick seal, but somewhere I've got a list of P/Ns for GM pans that used the thin seal.
Old Jul 11, 2005 | 06:21 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Thanks, if you can post the list sometime ti might help avoid my problems.
Old Jul 11, 2005 | 07:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I had it backwards. I've got 360010, 360409 and 465221 using the thick seal.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
