Did Top engine flush, engine won't stop smoking.
Old Jul 30, 2000 | 05:03 PM
Jester90RS
Guest
Posts: n/a
The kind of flush you hook up to a vacuum port and it's supposed to clean the carbon off your pistons?
It's been run about a hour total since I did the flush, but the smoking hasn't even really slowed down much. It seems to be running fine..if maybe just a little rough. is this normal?
Old Jul 30, 2000 | 08:51 PM
Jester90RS
Guest
Posts: n/a
btt?
Old Jul 30, 2000 | 09:27 PM
Vader's Avatar
Jester,
If you had heavy carbon deposits you may still be clearing them out. You may have also cleaned varnish away from the ring lands on the pistons. This may be causing temporary ring sealing problems and poor oil control. I'd keep a close eye on the oil level just to be safe.
Later,
Vader
"Some Body...Someone"
Old Jul 30, 2000 | 09:49 PM
dlp's Avatar
dlp
Howdy!
I have used a Top Engine Cleaner product by GM, in my Z71 half ton 4 wheel drive. It was recommended by a mechanic to immediately drive the vehicle, keeping the RPM's up to burn off the solvents in the cleaner. (Drove for about half hour)
This Engine Cleaner, smelled extremely toxic.
Is this similar to what you are using?
87 IROC -
ZZ4 350
SLP T-Ram,1"3/4 SLP headers, Cat back, Hotch-kis, MSD, Iebach etc.
Old Jul 30, 2000 | 10:13 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
GM top engine cleaner works wonders...
My car smoked for about 30 - 45 minutes....
If the smoke stays with you for more than that, then maybe your engine was dirtier than you thought...
If it stays a lot longer than that, then you might have a problem... Make sure to keep an eye on your oil....
Sportsman II 72 CC heads, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go shift kit, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
Old Jul 30, 2000 | 10:22 PM
Steve87Pont's Avatar
Wouldn't it be possible that like useing synthetics that it cleans the areas so much that the seals and all that were clogged by gunk have been opened up? Just a thought.
Old Sep 17, 2001 | 09:52 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
mine only smoked for about 10minutes.... maybe mine was very clean to begin with
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Sep 18, 2001 | 08:58 PM
zee28's Avatar
Car: 86 iroc
mine only smoked for about ten min.also.would not unhooking the air tube from cat do this?if you even have to,I do.just a guess
~mike~86 IROC-Z
Old Sep 18, 2001 | 09:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Where do you buy this stuff? and whats it called?
Old Sep 19, 2001 | 12:00 AM
R.O.B.'s Avatar
I just started working a Napa, and there is a product that they HIGHLY recommend for this, its made by SeaFoam. Never heard of it before, but apparantly its been around awhile. Anyways, one of the guys said he did it to his son's car, and it smoked for a week. After that, it finally returned to normal.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
1992 Trans Am
May 10, 2023 07:19 PM
Wade787b
Sep 29, 2015 01:15 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
