Engine pops and stalls, vacume? choke?
Old Sep 25, 2001 | 07:32 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Well I just got a new GM Goody 350 Crate engine droped in about two weeks ago. I had it installed by a mechanic my dad knows. Anyway this past week my engine has "popped" then the power cut out (but never died). This has been happening more and more frequant. I checked the vacume lines and don't see or hear any leaks. The choke is messed up so I set it back to where it is always open and it still does it. Any help would be great.
BTW. I have an Edelbrock 600 cfm carb (Non-comp., non-egr) sitting on a Preformer intake. I think the harmonic balancer is for a 305 and it still has the comp. controlled distributer. I'm buying a HEI ACCEL one and fixing the choke coil Saturday. If this has anything to do with it.
1984 Camaro Z28 - Black w/ Grey int.
Best 1/4 - 13.6 (5-speed) & 14.0 (Auto & 2.73!) Est. 300rwhp & 345 lbs.ft. tourqe
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, ACCEL wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrom valve covers, breather, and Air cleaner.
-TH350 with Hurst shifter & B&M Street shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
Comming Soon:
3.73's, MAC Cat-Back, hollowed cat. & Paint: Navy Blue Metallic w/ Silver strips
Old Sep 25, 2001 | 07:36 PM
firbird's Avatar
does it also not wanta go past a certain rpm like 2500 mine did the same and it turned out to be timing.
Old Sep 27, 2001 | 05:51 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
It does seem to happen around 2500 rpms. Has anyone else had this problem?
-Matt
Comming Soon:
Old Sep 27, 2001 | 08:28 PM
RS91's Avatar
Have you checked your 02 sensor?
Old Sep 28, 2001 | 02:53 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
No O2 sensor for me. All Smog and slow down equiptment has been removed.
Old Sep 28, 2001 | 10:12 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
That CC distributor isn't helping anything, I wouldn't drive it until you get a NON CC one. That might be your problem right there. But also make sure the choke is adjusted properly, did you do it according to the manual. Also check to make sure you don't have any burnt plug wires as this has happened to me too.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 28, 2001 | 10:16 PM
Car: 99 Formula
Axle/Gears: 342
Also I was wondering, I have the same engine as you along with some other mods? Not saying I dont' believe you, but how are you running 13's with out exhaust and those gears. Also why do you estimate it at 300rwhp. That engine dynoed, with a q-jet, open headers, HEI dist., and cast iron intake puts out a max of 250 hp.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Old Sep 28, 2001 | 10:17 PM
Car: 99 Formula
Axle/Gears: 342
And that's at the crank not rwhp.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
