could tapping sound be a rocker issue?
Old Jul 28, 2005 | 12:57 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I have a tapping sound from the engine bay (I'm pretty sure its a lifter) but i know that the rockers were changed a while back and they were never re-adjusted...could this tapping sound be fixed by adjusting the new rockers? thanks (ya, i know its probably a tech/general post/question but my car is a TBI so why not keep the post within our own TBI group?, hehe )
Old Jul 28, 2005 | 01:40 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The LO3 is no different from any other SBC . And besides, youll get more views in the Tech/Gen. engine .
Old Jul 28, 2005 | 04:46 PM
Ann.racer92's Avatar
Car: 92 Camaro Heritage RS
Engine: 5.0
dude i had that noise and while it could be a lifter mine comes from my AIR pump, i litteraly blew it at the track pulling too many rpms, like 5750 in second trying manual shifting, dont do that by the way. i still havent removed it but it ticks like a mother, you can hear it inside the car and its slowing me down.
my goal is to get back to the 15's with it on and remove it.
just a thought but if you can afford the spare serpentine belt try skipping the air pump, might save some time.
Old Jul 29, 2005 | 09:07 AM
Car: 1988 SC Camaro
Engine: 305 TBI
actually, my air pump is removed from my car...but the air tubes are still there (and they are open)...not only am i getting the "ticking" noise but there is also an exhaust smell as well...
Old Jul 29, 2005 | 09:15 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
actually, my air pump is removed from my car...but the air tubes are still there (and they are open)...not only am i getting the "tivking" noise but there is also an exhaust smell as well...
You need to plug the holes on the manifold. Then maybe you will be able to hear the ticking noise a little better. SOmetimes an exhaust leak can make a ticking noise
Old Jul 29, 2005 | 09:19 AM
Car: 1988 SC Camaro
Engine: 305 TBI
what about the rocker arms?...is it true that new rocker arms need to be adjusted after time?....could this possible cause any type of ticking sound?
Old Jul 29, 2005 | 09:46 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Absolutely, just pull your valve covers off and check them, grab ahold of the rockers and see if there is too much movement, you should be able to move them very much. Bump the engine over then check them a few at a time
Old Jul 29, 2005 | 11:26 AM
Engine: 5.0
i got ticking before i removed my air lines id try pluggin them, just stick your finger over them and that should kill it if thats it
sweet_87_iroc
Sep 25, 2015 10:01 PM
Cameeeero
Sep 18, 2015 04:00 PM
db057
Sep 4, 2015 07:57 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
