Car dies when stopped
Old Oct 16, 2001 | 05:40 PM
Thrall's Avatar
So here is the story: It is a 89 firebird formula, I got it about a week ago. It ran fine when I got it (actually it ran fine about 6 hours ago), but on my way home today the damn thing kept dying.
It starts fine, but everytime I stop at a light it dies, any time I let it idle for even a little while it dies. and I have to wait 30 seconds or so before it will start again. The service engine light it also on.
Any ideas?
T.
Old Oct 16, 2001 | 07:00 PM
firbird's Avatar
make sure the min air is set right
Old Oct 16, 2001 | 08:28 PM
iroc5speed's Avatar
if the SES light comes on check to see what codes you're throwing.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Oct 21, 2001 | 06:50 PM
gmanuel's Avatar
If your car is an auto, check that the torgue converter lock up is disengaing. To test you need to drive the car on the highway at cruising speed, engine at normal operating temperature and press the brake pedal lightly. You should notice the engine rpms increase. If not then the TLC is not releasing. If when you come to a stop if the engine starts to dry then put the tranny into netural.
Old Oct 21, 2001 | 07:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I second the TC lockup working properly.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 21, 2001 | 11:29 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Still could be the fuel pump though.
do a Fuel pressure test just for the Hell of it...
Old Oct 22, 2001 | 11:15 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I had the same problem with my car. It turned out to be the MAF.
Old Oct 23, 2001 | 01:56 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
I'll go out on a limb and say it could be your EGR valve sticking open. During mid throttle driving the EGR will open, but is suppose to be closed during either WOT or idle. If it isn't closing when you're coming to a stop it can cause a rough idle, or no idle at all and stall the engine. An improperly functioning EGR will cause your check engine light to come on ( i forgot which code # it is).
Red '87Formula Firebird
-mostly stock 5.0L LG4 w/cowl induction setup borrowed from '83 TA and T5 tranny.
[This message has been edited by RedFirebird (edited October 22, 2001).]
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
