ANSWER QUESTION DAMMIT
Old Oct 18, 2001 | 10:16 PM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
I have a 91 305 tbi firebird i had a roller rocker cam and i changed it to a 194/214 at .05 i put headers on and a new intake. it was a edelbrock intake cam combo.The headers are pacesetter and i have no cat and i have a hypertech chip.ASK IF U NEED MORE INFO. IM TIRED OF DRIVING MY CAR THAT IS RUNNING HALF ASSED. I have the timming advanced 8 degrees and i have my fuel regulator maxed out. the car has a kinnda sputter when i pound on it and i winds up slow NO TORQUE it backfires through the tbi every once and awhile kinnda often. I got on it hard for a 50 yard shot i was in first its a (auto)and i stoped at the next stop sign and it died. I go to school on a 300 yard hill and it hits about 70 and runs about 3 grand and it almost stops accelerating and if it does accelerate it stays at 3,000. It doesnt want to wind rpms like the car did before the mods. PLEASE HELP ME MY CAR HASNT RAN RIGHT FOR A LONG TIME. IF U CANT HELP GET SOMEONE THAT CAN PLEASE.
Old Oct 18, 2001 | 10:19 PM
iroc5speed's Avatar
sounds like a vacuum leak to me. your timing sounds fine, but spray some carb cleaner around the intake and throttle body with the engine running and if the rpms jump then you need to reseal the part with the vacuum leak. Vacuum leaks are very frustrating, but easily cured, unless you have warped parts. Good luck
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Oct 18, 2001 | 10:59 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Take off each spark plug wire to make sure it hasn't been laying on a header and burnt thru. This has happened to me 3 times and I just finally learned the wonders of wire looms, plus I bought heat protective sleeving.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 18, 2001 | 11:00 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Your topic title sucks.....could you be more pushy??
Anyway, are you sure you set the timing marks on the gears correctly??
Whats the fuel pressure.??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited October 19, 2001).]
Old Oct 19, 2001 | 09:50 AM
Biochem's Avatar
Car: 2002 SOM z28
<font face="Verdana, Arial" size="2">Originally posted by 91firebirdfosho:
the tbi
</font>
Well, I think I found your first problem. Next, it sounds like you are running a little rich with that regulator maxed out. What gears are you running? Torque convertor? That isn't really a big cam, so it shouldn't be a real deal breaker... LSA and lift on that cam? Your hypercrap chip may have a big impact on things too, but I'm not a TBI expert.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Oct 19, 2001 | 10:15 AM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
You catch more flys with honey than vinegar. Try asking nicely. These people here don't owe you anything.
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Oct 19, 2001 | 11:04 AM
ede's Avatar
ede
i have a pretty good idea about your problem. maybe if you beg i'd answer but not the way you posted it.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 19, 2001 | 12:08 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I have a good idea of what the problem is too, it starts with your attitude....
Old Oct 19, 2001 | 01:00 PM
82z's Avatar
82z
What do you mean your regulator is maxed out? I've never heard that before. You didn't mess with it did you? There is nothing you can do to a tbi regulator.
Old Oct 19, 2001 | 01:51 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I thought the edelbrock TBI intake/cam combo was for trucks. Using a flat tappet cam instead of roller cam. Did you toss your roller stuff and replace with flat tappet? Did you break the flat tappet cam in for 30 min at 3k rpm before driving?
Old Oct 19, 2001 | 03:50 PM
kevinc's Avatar
Car: 1982 Z28
I'm pretty sure I know what's wrong, very easy to fix if this is the case.
Start begging, dumbass.
Old Oct 19, 2001 | 05:53 PM
JETHROIROC's Avatar
I know too, DAMMIT .
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 20, 2001 | 10:10 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by ede:
</font>
ede, how is it you beat me to every one of these posts?!? Now I can't have any fun.
"Question with boldness even the existence of a *** ; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Oct 21, 2001 | 01:01 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i agree about the first problem being the attitude. once again someone all mad about trying to fix a problem they caused. what are your O2 readings when your on it? does the knock sensor show any counts? what are the readings form the map sensor?
Old Oct 21, 2001 | 07:51 PM
Engine: 383
Transmission: th350
SORRY ABOUT THE POST NAME IM JUST DISGUSTED WITH MY CAR I DONT THINK I NEED A ATTITUDE CHANGE BECAUSE IM THE NICEST MOST QUITE PERSON YOULL MEET.I DIDNT KNOW THAT IT WOULD OFFEND PEOPLE I JUST WANTED TO GET PEOPLES ATTENTION WORKED DIDNT IT. OHH MY NAME IS NICK NOT DUMB *** OR JACK *** THANX ALOT IM NOT A BEGGER EITHER I WAS WONDERING HOW YOU MEASURE KNOCK OR CHECK IT AND THE OTHER THING U SAID
Old Oct 21, 2001 | 07:59 PM
firbird's Avatar
please do not use caps, i find it as if you were yelling at me, and calm down
Old Oct 21, 2001 | 10:37 PM
speedlvr's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 82z:
What do you mean your regulator is maxed out? There is nothing you can do to a tbi regulator. </font>
You can make it adjustable. There's a tech article on how to do it. Not that it really does any good anyway...the chip has the last say.
What 91firebirdforsure needs for sure is to switch over to carb. He'll be a happy camper if he does.
Old Oct 21, 2001 | 11:40 PM
zippy's Avatar
Engine: 5.3L
i measure knock and the other stuff with a tech 1.
Old Oct 21, 2001 | 11:41 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Oh yeah..yelling is much better...
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Oct 22, 2001 | 08:34 PM
Engine: 383
Transmission: th350
I WASNT YELLING I JUST HAD CAP LOCKS ON NOW IM YELLING CUZ WHO EVER BITCHES IS A BIG FAIRY. YOU GUYS THINK TOO MUCH AND IF U COULD ONLY SEE HOW CALM I AM NOW I WENT FROM CALM AS HELL AND NOW IM TESTY
Old Oct 22, 2001 | 08:57 PM
jmon92conv's Avatar
Is it just me, or does it sound like sexual frustration????
Old Oct 22, 2001 | 09:03 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Now we are "Big fairys"......hmmmm.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Oct 22, 2001 | 09:18 PM
Hulk0202's Avatar
I had a similar problem. I couldnt pull past three grand, it sputtered when I florred it. In my situation it was a clogged cat. Take off the airfilter and rev that sucker up. If it sputters out of the tbi, check your cat. The rest of you are a bunch of women(no offense to any fine young ladies out there). Are you really bothered by the way he words it or types it? Lots of help ladies! Good luck bro. Dont give up because when you fix it you'll love it again.
tpi_roc's Avatar
*tosses fairy dust around the room*
Old Oct 23, 2001 | 12:19 AM
ONEFORMULAOVERALL's Avatar
what? u got testes in yo car?
id be mad 2
ony 36 posts and already cuttin a tude
bro maybe u should sell yo car,buy a stank and jump on there site!
the laid back bird aint yo style!
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4B&MSATURDAY NIGHT
SPECIALTRANS 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,L-98 ALUM. HEADS PORTED CRANE AFPR.45PSI,SMOG PUMP GUTTED,
UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 DUMP
MSDDIST,6AL,TAYLOR WIRES
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.23 AND MOSER AXEL SPLINES CRYGO FROZEN,TUBE FRAME CONNEC,EIBACH PRO.,HOK.LOWER ARMS,PAN,TQ ARM,ALUM. DRV.SHAFT.
PST KIT.1LE BRAKE KIT CROSSED DRILLED ROTORS MANY MORE MODS FORESEEN IN MY ERA!13.38ET @ 107.75MPH
Old Oct 23, 2001 | 12:07 PM
Biochem's Avatar
Car: 2002 SOM z28
I'm about 185lbs and 6'... am I a "big fairy"? What does that make Jester... a bigger one? Ed must be a "midget fairy", or do you call yourself a "pixie" or something Ed?
Old Oct 23, 2001 | 01:43 PM
u r sofa king we tah did's Avatar
id have to agree, seems to me like this kid has alot of sexual frustration. its not our fault you cant get laid 80% of the people on here could help you out and probably have a good idea what your problem is on your car, but i seriously doubt your gonna get much help now.
Old Oct 23, 2001 | 07:38 PM
ede's Avatar
ede
ok guys i think we've all had a little fun with this one. i guess it's time to lock it. maybe he'll come back again and play a little nicer with us here at thirdge.org next time he has a problem.
Red iroc-z 305
Sep 30, 2015 05:22 PM
TEEZER TA
Aug 30, 2015 06:35 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
