I have a chance at a free blown 305 longblock, opinions?
Old Nov 4, 2001 | 01:34 PM
Xenodrgn's Avatar
Alright, I was talking to a guy in my area and he is parting out his Trans Am because his 305 blew... something in the bottom end... he said I can take it for free.
I need a new tranny anyway, so it's a matter of buying a V6 or a V8 tranny...
Do I keep the V6? Or rebuild the 305?
The 305 is a crossfire injection one, I'm thinking LG4, supposedly a pretty ****ty engine, but it's still better than my LB8. Right now I'd do anything for an 8...
So... opinions? And please don't bash this post, I know I'm asking for it... I just want a good clean discussion.
Thanks!
Old Nov 4, 2001 | 02:34 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I guess it all depends on how much money you are willing to spend on a rebuild. But why is the guy giving it away for free. Go ahead and take it worst comes to worst you don't rebuild it, but later down the road you can. If the motor makes any amount of decent HP after a rebuild, you'll have to rebuild the tranny.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 4, 2001 | 02:40 PM
rezinn's Avatar
A 305 is better than a v6 as far as power goes, you can make them pretty quick. The one thing I don't like is the crossfire injection; if you could get a different intake on it, that would be great. Would that be plausible?
Old Nov 4, 2001 | 03:00 PM
Guest
Guest
Posts: n/a
It could be a doorstop too, keep that in mind. I guess it couldnt hurt to pick it up and find out whats wrong with it if you have the means to do so.
Old Nov 4, 2001 | 03:22 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
FYI, eveyone has access to a free blown 305, I'd say look around you can probably pick up a running 305 for less than $500, which is more than likely alot cheaper than you will get that blown 305 rebuilt for. Also you don't know what's wrong with it yet, could be major, crank, block crack etc. I say skip it.
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
Old Nov 4, 2001 | 07:07 PM
leirch's Avatar
Its free, go get it, take it apart and while taking it apart, if you can tell something major is wrong, throw it away, what are you out? A few hours of your time?
Brendan
Old Nov 4, 2001 | 07:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You'll probably spend more repairing a free blown-up 305 then you would if you went to the boneyard and bought a running 350, and just freshened it up a bit... although like the one post said, you could tear it down and see if it's really wasted or what, maybe it's not so bad (could be fixed with just a cracnk kit or something), at least you might learn something if you've never been inside an engine's crankcase before.
But if it really is "blown up" to where the pistons have to come out of the bore (spun rod bearing or broken rod or damaged piston), it's not a good way to go. Pass on it. The "core" for an engine swap is usually the least significant part of the total cost of the swap; If I was going to go to the trouble and expense of doing a swap like that, I'd aim a little higher than a minimum V8.
ICON Motorsports
Old Nov 4, 2001 | 07:24 PM
coach's Avatar
Hey, you tricked me! I thought you meant blown/supercharged
All kidding aside. Like the posts above me have stated, the blown 305 may have some major problems or minor problems. Whether it's worth the trouble of hauling it home and dismantling it is up to you. It may very well be a good find.
There's also the problem of the actual swap. Who knows all the little things that may need to be changed/altered, such as: exhaust, ecm, wiring, radiator, fuel line/pump, etc.
If the 305 is in need of a rebuild, it would probably be better to find/buy a rebuilt 350 or one that's already running. In the end, it's all up to you, and how much you are willing to invest(time, money, etc.). Whatever you decide; good luck.
[This message has been edited by coach (edited November 04, 2001).]
Old Nov 4, 2001 | 07:41 PM
Car: 99 Formula
Axle/Gears: 342
<font face="Verdana, Arial" size="2">Originally posted by coach:
Hey, you tricked me! I thought you meant blown/supercharged </font>
Same here, but I figured he would keep the blower.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Old Nov 5, 2001 | 03:30 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
buy the car before he parts it out. That way you've got a V8 car to start with. Buy a used/running 350 longblock (or get a cheap/free 305 longblock) and get it running. Way easier than trying to convert to a V8 from a V6 (legally).
Just my opinion on an easier way to a V8
Clem
BTW "Mark A Shields" your sig is weak and offensive. You ought to change it and quit post whoring.
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old Nov 5, 2001 | 04:08 PM
Car: 99 Formula
Axle/Gears: 342
<font face="Verdana, Arial" size="2">Originally posted by clemsparks:
Clem
</font>
I'm sorry I didn't think I would be offending people in a thirdgen site, but is that better.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Old Nov 6, 2001 | 09:12 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
no,
and one more point. Once you've posted in a thread with your sig...You don't have to post the sig with every successive post in that thread. Once is good enough.
It's not that it's so offensive, as it makes you look like an idiot. I don't like to see people making idiots of themselves unknowingly. Now you know.
sorry for the O.T. It's just been bugging me.
Clem
Old Nov 6, 2001 | 09:19 AM
Xenodrgn's Avatar
sorry for the O.T. It's just been bugging me.</font>
Been bugging me too, but not to the point where I'd risk a flame war over it.
Anyway, thanks for the opinions guys, I'll just buy a V8 car down the road. If I decide it's worth the trouble, I'll pull it and see if I can sell it/part it out for a few bucks...
Old Nov 6, 2001 | 11:06 AM
Car: 99 Formula
Axle/Gears: 342
no,
Clem
</font>
Sorry if it makes me look stupid, it just gets on my nerves these days. I don't see any Mustangs or Camaros riding my a$$ up a mountain once I pass him. Then having him fly by me only to slow down, when I was only driving not racing. It's crap like that, that gives me my opinions on the Rice subject, and since when did you become a moderator telling me when to show my signature or not, don't you think I have thought of that, I'd rather just make a habit of always clicking it.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Old Nov 6, 2001 | 02:54 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
You're right, I'm not a moderator. I'll respect your opinions. I'm not telling you what to say or when to say it, I'm simply telling you how I feel about what you say and when you say it. That habbit is annoying and bad "board ettiquite."
We can agree to disagree, no biggie.
Clem
colton_carlson
Mar 8, 2019 12:21 PM
onefreakz
May 14, 2018 12:15 PM
beastin91rs
Oct 9, 2015 07:38 AM
Thornburg
Aug 25, 2015 01:46 AM
theurge
Aug 21, 2015 12:46 PM
