open element installation trouble
Old Nov 17, 2001 | 05:43 PM
tacoboy's Avatar
Hey, I just got my Comp Cams open element air filter the other day, and here is my problem. The base plate for it will not clear my plug wires at the distributer. I have a performer intake manifold and a stock distributer. The carb is a qjet. The element is 14x3. Anybody else have this problem with their filter? Anybody have a solution? Thanks.
Old Nov 17, 2001 | 05:59 PM
killer305's Avatar
is your element droped, you might have to buy a spacer. make sure not to ground out your coil or your ecm will be cooked
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
Old Nov 17, 2001 | 06:36 PM
tacoboy's Avatar
no its not dropped, but it at least couldnt ground the coil...its a Comp Polymer.
Old Nov 18, 2001 | 12:10 AM
Enkil's Avatar
They make offset open element filters for this. Basically, the hole that the fits around the carb is closer to the edge of the metal disk than the center, so the whole thing is shifted forward a few inches.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Nov 18, 2001 | 02:57 PM
tacoboy's Avatar
well that would make my current element worthless, i decided to try an edlebrock element spacer thing, maybe that will work
Old Nov 18, 2001 | 05:17 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by tacoboy:
well that would make my current element worthless, i decided to try an edlebrock element spacer thing, maybe that will work </font>
Yea, I had to do the same thing. Get a 1in spacer and you should be set.
SSC:0
Old Nov 18, 2001 | 05:25 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I have the GM drop base air cleaner. 65/70
Z28, corvette.
Your comp cams air cleaner is fashioned
after this one. Mine comes real close
to the HEI distributor cap, right at the back. I flattened the edge of the base and turned the wires away from the filter, to add a little more clearance. I'm useing the Performer RPM Vortec and a Holley carb.
Old Nov 18, 2001 | 10:16 PM
tacoboy's Avatar
1/2 in spacer worke.
mdtoren
Aug 23, 2015 12:52 PM
djmarch
Aug 19, 2015 12:07 PM
mdtoren
Aug 16, 2015 05:45 PM
wruiz
Aug 13, 2015 09:07 PM
