what cam for this engine combo????
Old Nov 19, 2001 | 09:51 PM
Stang Eater's Avatar
i am in the process of building a new motor for the spring, my car is a 91 Z(SD) origionally a 350, im building a 355, 4 bolt, pink rods, keith black forged flat tops, dart sportsman heads( 2.02, 1.6), crane roller rockers, accel 24# injectors, edelbrock 52mm TB, ported plenum, SLP or AS&M runners( havent decided) and an edelbrock base, i already have MSD Digital 6, MSD blaster coil, MSD wires etc. Now i just need to pick a cam and lifters, any ideas?i was looking at the Lt4 Hot Cam, or comp cams 08-302-8, 210 220 dur @ .050, 480, 480 lift, 112 LSA, to me the hot cam seems a bit wild and the comp not enough for the combo, what do you guys think???
Old Nov 19, 2001 | 10:05 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have a stock L98 shortblock, TF Heads, edelbrock intake and ASM runners. I picked out comps 08-502-8 Xtreme 218/224 496/502 112 LSA no results. Parts are still in the box.
Old Nov 19, 2001 | 11:12 PM
GOLD85's Avatar
do u want solid or hydrolic lifters
when the green flag drops the bull$hit stops
Gold 85 Camaro with no motor, pulled the 2.8 to make way for a 350 wich was pulled this summer because a 406 will replace it. The 406 sports a stock bottom end with ARP bolt holding it togeter, flat top hyper pistons. Comp 282 solid cam(.528 lift with 1.6 rockers) Savin up for my Sportsmen 2 heads right now. still Have the perf RPM and 650 DP i used on the 350. Headers and 3inch exhust. Shooten for mid to low 12s next summer
Old Nov 20, 2001 | 06:48 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I would go with the LT4 hot cam. I don't think it will be too wild. I hope not I have mine in the box for my buildup. It does have a lot more lobe than the LT1 cam I just put in my truck.
Old Nov 20, 2001 | 01:18 PM
thanks for the replies, keep em comin,
and i would like to stick with a hydraulic roller, but if you have a differetn set up idea, feel free to suggest, this is my first engine build up, so im open to ideas, thanks again guys.
Old Nov 20, 2001 | 03:11 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
HOT cam, HOT cam, HOT cam. Take a look at Kevin91z or Jason Aschle. 107 mph+
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Tremec TKO
Pro 5.0 Shifter
GM posi 3.42 rear
Hurst Roll Control
13.9@102
http://www.geocities.com/thetpiguy/index.html
Old Nov 21, 2001 | 12:32 AM
Ride4ME's Avatar
I have a LO3 TBI and was wondering how much a LT4 Hot Cam would cost including installation.
Black 91 RS
Dual Exaust Flows
"My First Car"
Old Nov 21, 2001 | 02:15 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Hot Cam, definitely. That comp's 302 seems a bit too small. And definitely stick with the roller cam, a hydraulic one will pissoff the computer. Ride4Me, IMHO the LT4 hotcam is too big for a 305. Even that comp 302 would be a little big unless you had some other good mods, like heads and exhaust. And the price of a cam install will just about break ya.
91 Z28
Come see The Vicious...
Old Nov 21, 2001 | 04:19 AM
poncho9789's Avatar
HOTCAM.
You can get the hot cam from scoggin dickey for only $175 and you can get 1.6:1 roller rockers cheeper than thay want for the GMPP parts.
89 GTA w/700r4w/stage 2 shift kit,2800 converter, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body, Ported Edelbrock centerbolt heads,Accell 30# injectors,holly afpr,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil,150 shot NOS. The new engine is in but I am still having some small problems.
Old Nov 21, 2001 | 11:25 PM
Nordbert's Avatar
www.sdpc2000.com also has new parts taken
from crate engines.
Old Nov 23, 2001 | 03:13 PM
whats the lt4 hot cam from?? or is it just a GMPP camshaft????
1984HO
Mar 19, 2021 11:59 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reborn756
Sep 4, 2015 03:42 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
