carb spacer
Old Jan 17, 2006 | 08:18 AM
toofast's Avatar
carb spacer
I put a 1/4 spacer under carb now it whistles loud.
Stock 350 chevy in my Elky edelbrock 750. Anyone (heard) of this.
Old Jan 17, 2006 | 08:47 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
is it affecting the performance at all or just making noise? how loud is it?
Old Jan 17, 2006 | 09:18 AM
toofast's Avatar
No its not hurting anything .You can here it standing beside the car but not while you are driving.Open spacer i made out of wood.
Old Jan 17, 2006 | 09:45 AM
Vacuum leak
It's not covering all the holes properly; either the intake, or the bottom of the carb. Somewhere, vacuum is escaping.
Old Jan 17, 2006 | 09:53 AM
toofast's Avatar
Thanks ill check that tonight
Old Jan 17, 2006 | 09:56 AM
Just look for the pile of vacuum on top of the intake Don't forget to use the special tool to clean it up, known as a "vacuum cleaner"
Old Jan 17, 2006 | 12:53 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I had an identical problem.
I looked all over for vac leaks and there were none, it was whistling loud at idle and it would go away by 1/4 throttle.
It ended up that the spacer was misaligned with the throttle bores. The edge of the spacer was protruding slightly into the airflow just below the opening of the throttle blade at idle, creating a perfect whistle.
Another thing that can create a whistle is a PVC port that goes directly into a throttle bore (cheap spacers only)
Old Jan 17, 2006 | 10:51 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
sloved before i finished reading.
sorry posted two late...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
