new mini high torque starter
Old Mar 23, 2006 | 01:50 PM
86interceptor's Avatar
Car: 86 Z-28 Police Interceptor
Engine: 305 but building a 350
Transmission: 700r4 with shift kit
I jsut bought a new mini starter and when I installed it and tried to satrt the car the bendix will not kick back after starting. I have tried many diferent shim combos and still no luck. it also makes an odd high pitched sound when turning over. did I give up to soon on shimming it? is there something wrong with the stater? please help this is all that is keeping from driving my car with the new 410hp 400sbc
Old Mar 23, 2006 | 06:26 PM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
mini starter
try bolting the starter up with no shims, might work, if not there may be a defect with the new starter, yes its new but still there could be something wrong internally with it. Also if all is well with no shims or you end up replacing it, it might not hurt putting a grond wire from one of the starter bolts to the frame while your under there, alittle extra grounding protection doesnt hurt a thing. Good luck.
Old Mar 23, 2006 | 08:28 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
bendix may be binding and staying engaged do to the angle of alignment. keep working the shims or getting rid of them completely. High torque starters have a higher pitch by design usually.
Old Mar 23, 2006 | 10:24 PM
I got to looking and the gear is to close to the flywheel. it looks like the starter motor needs to be moved back from the starter mounting plate. does any one kow if I can get any shims to do this
Old Mar 24, 2006 | 09:13 AM
doesn't anyone else have any suggestions?
Old Mar 24, 2006 | 09:51 AM
If it's a Hitachi starter, there are shims available to move the starter motor back from the mounting block. I think this is it. http://store.summitracing.com/partde...art=CSI%2D100S Nippondenso starters don't need that.
Old Mar 24, 2006 | 10:27 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I had a post about this a long time back...
https://www.thirdgen.org/forums/tech-general-engine/330941-can-i-salvage-starter.html
I eventually just went ahead and bought another starter for $78 shipped (just like that one) cause I didn't trust the gear on my new SFI flexplate.
I had to shim the new starter also. I did it the same way worked great!
Old Mar 26, 2006 | 11:28 AM
I took the starter to the local performance shop and they gave my the correct shim for it and it works like a charm. thank you all for your suggestions. I always send all my friends to this site for their questions. Ihave never found a site that can answer just about all autop tech questions.
thanks guys
bbsr72
Sep 27, 2015 05:55 AM
Nick McCardle
Sep 10, 2015 08:36 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
