Running Rich! I know this is ghetto... FPR
Old Apr 2, 2006 | 03:11 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Okay here is my scenario... I had a V6 MFI Swapped it to a 4BBL V8
so I put a mechanical pump on the V8 and it would seem to vapor lock (since it was pulling through the electric pump.
When it would vapor lock the car would die. So I took off the mechanical pump and wired up the electric pump.
I have a fuel pressure regulator in place I am guessing three port.
the arrows look like this
__
( <-- V --> )
The line from the tank is connected to the bottom
the on to the right to the carb
the one to the left blocked off....
the fuel tank return i blocked off... I tried connecting that to the left line on the FPR but the car never got fuel...
so the way i have it hooked up now ... it gets like 5 PSI and soaks up my fuel like crazy.... tune it down anymore it dies...
drains my whole tank within 100 miles...!!!!
someone help me?
Old Apr 2, 2006 | 07:19 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
__
( <-- V --> )
someone help me?
what fpr do you have? I just did a mallory return style on mine. helped out alot.
Old Apr 3, 2006 | 10:00 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Its some sort of holley.... I am not sure but I hope someone has some sort of insight on this...
Old Apr 3, 2006 | 11:04 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
First off i would rig up the return line, thats got to be hard on the pump having it blocked like that!
Old Apr 3, 2006 | 09:22 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I will un block the return line and hook it to the regulator and see if that helps I dunno
Old Apr 7, 2006 | 06:47 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I connected the return line and the car runs fine.... but I am still running way too rich... I have to fill up after 2 days... I drive maybe 40 miles a day
Old Apr 7, 2006 | 10:01 AM
Vader's Avatar
Reduce the fuel pressure at the carb to 3-4 PSIG. Make sure the float, inlet needle, and seat are operating properly. The rest is in carb tuning.
Old Apr 10, 2006 | 10:50 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I have it tuned to about 2-3 psi and it runs super rich. if I tune it down more the car bogs at high RPMs I know I dont need that much fuel since you can smell the gas for sure and it eats a tank in a couple hours. I guess I will have to look up carb tuning.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
squiggy2
Aug 9, 2015 09:30 PM
