Still Stumped????
Old May 2, 2006 | 07:08 PM
lyllibido's Avatar
Still Stumped????
I began a thread earlier regarding this topic. 91 350 Z-28...new o2 sensor, knock sensor, CTS, plugs, wires. Here's the problem. Car starts up fine, runs strong, no SES while running (it does work). Once the car runs for about fifteen to twenty minutes it dies as if I am out of gas and won't start until it completely cools down (approx. 4 hours). Most of the responses I got said that it was my fuel pump; that sounded good to me. I had it replaced and it is still doing the same thing. I'm not too knowledgeable about open and closed loop, but when it warms up and it is in open loop, it begins to idle a bit rough and this is around the time that soon after it dies on me and won't start up. When I try to restart it, it turns over but it acts like I am out of gas. Your help is greatly appreciated. Thank you!
Old May 2, 2006 | 07:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Sounds like an ignition component failing when hot (ign module, coil, something to that nature).
Old May 3, 2006 | 09:03 PM
lyllibido's Avatar
I bought a ignition module at the dealer today...put it in and it still did the same thing. One thing that I did notice when I took the distributor off was that there was a fair amount of powdery rust on whatever the distributor rests on. What does this mean? What should I try to change next? Any other ideas? Thanks for your help!!!!
Old May 3, 2006 | 09:09 PM
dustpusher's Avatar
Car: 88 IROC-Z
Check your pick-up coil on your distributor.I had one go bad on my 92 GMC. Sounds like same problem.
Old May 20, 2006 | 07:13 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
pick up coil = pick up assembly?
what are some other symptoms of the dead or malfunctioning pick up assembly?
Old May 20, 2006 | 09:11 PM
dustpusher's Avatar
Car: 88 IROC-Z
My truck would run untill it got up to temp.Then it would die like it ran out of fuel.I started changing pump,filter,complete tuneup and ignition control module.Didnt help.The pu coil is under cap and plugs into control module.It would only act up at temp and it was random.
Old May 20, 2006 | 09:17 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Did you replace the cap and rotor when you did the plugs and wires?
Old May 20, 2006 | 09:20 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
could the pickup assembly cause the car to choke and sputter under load, but still idle properly?
Old May 20, 2006 | 09:36 PM
dustpusher's Avatar
Car: 88 IROC-Z
It did on my truck.But it was random.To change it you have to pull dis out and knock a roll pin out.Mine had a bunch of carbon in the shaft so ibroke dis trying to change pu coil.I had to drop 100 bucks for a new dis.Could have only spent 10 if I didnt break dis.
Old May 21, 2006 | 03:15 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
you have to knock a roll pin out? or can you get away with it for now?
Old May 21, 2006 | 11:16 PM
dustpusher's Avatar
Car: 88 IROC-Z
Yes I did change cap+rotor.Ichanged every thing I could think of.After I figured out it was pu-coil I pulled distributor,tried to change pu-coil and broke distributer.The roll pin is at bottom of the distributer through the gear.You knock it out and pull the shaft that the rotor goes on out.Mine had a bunch of carbon in it and I broke it.After you got it apart pu-coil is held in place with three small screws.Hopefully you wont have the problem with breaking the distributer like I did.
Old May 22, 2006 | 03:10 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
ok thanks
Old May 22, 2006 | 05:41 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i just got my car back this week. i had the same exact problem last week. it was in fact the pickup coil. cept i went and replaced the carp rotor coil ign module and the pickup, so it could have been one of those too. i was thinking the same thing with the feul system. the thing that threw me off is when i tried to start it again, it smelled like gas, so i knew it was getting in the engine.
Old May 22, 2006 | 07:57 PM
dustpusher's Avatar
Car: 88 IROC-Z
So I take it that it fixed your problem.I was very frusterated with mine until I figured it out.Mine was just my truck.I can imagine having your camaro down during nice days really stinks.
Old May 22, 2006 | 08:12 PM
ZZ4 86 Z28's Avatar
yea, its been down since october. tranny blew up. finally saved up enough for the rebuild (17 years old here) and i take it about 3 blocks, and it started acting like that. but now its finally ok...i think. i got new codes today, maybe i shouldnt have gone with such a highly modified car...but it sure is fun.
Old May 23, 2006 | 12:25 AM
lyllibido's Avatar
I tested the coil; seemed to be fine. I connected a brand new AC Delco one that I had and never used. It idled for about twenty minutes then it died again, just like before. The only thing left is the pick-up coil. For a novice like myself, it seems too difficult to change. May pay someone else to do it. Thanks for your help fellas; I'll let you guys know what happens when I change the pick-up coil.
Old May 23, 2006 | 12:38 AM
dustpusher's Avatar
Car: 88 IROC-Z
Good to see the younger gen in third gen instead of a ***** for a change. Looks like maybe theres hope for the younger gen.Nice ride for 17 and good work with it.
Old May 23, 2006 | 09:28 AM
ZZ4 86 Z28's Avatar
thanks man, its pretty much been my life. between this, the band, school, and a job, i dont really have any time to do anything else. but its worth it.
Old May 25, 2006 | 01:52 AM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
BE EXTREMELY CAREFUL when removing the shaft in the dizzy to change the coil, use lots of oil to get the shaft to move better and dont use a vice! lol
Hey! Im young too!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
