Oil Pressure Gauge
Old May 18, 2006 | 09:19 PM
zrated57's Avatar
Oil Pressure Gauge
My oil pressure gauge is maxed out while driving or at idle. The only time it ever moves is when the car is being started. When the car is started it will drop to zero and then shoot right back up to 12:00 or max position. I was wondering if there was a way to test the oil pressure sending unit? I have ruled out the gauge being faulty because I installed a different gauge cluster and the oil pressure gauge gave the same reading as the old cluster did. Any information on this subject would be greatly appreciated. Thanks in advance.
Old May 18, 2006 | 09:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
mechanical gauge...
Cheap as dirt!
Old May 19, 2006 | 07:51 AM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Have you tried to replace the sending unit with a new one? If not try that first.
Old May 19, 2006 | 01:56 PM
zrated57's Avatar
I haven't replaced it yet, but that was my next step. Does anyone have instructions on replacing it?
I have also just started to notice a medium sounding whine/tick noise coming from around the distrubutor area. I cannot pin point the noise and I don't think it's the valve train or the fuel injectors. I can hear it inside the passenger compartment also, but it seems to be coming from the distrubutor area. Can the FPR make noise or maybe the oil sending unit? I have posted this in another catagory.
Old May 19, 2006 | 02:00 PM
Unplug. Unscrew. Re-screw. Re-plug.
Not a big challenge.
Can't comment on the noise, except that it's probably not the oil pressure sending unit.
Old May 19, 2006 | 08:37 PM
zrated57's Avatar
Thank you. A buddy of mine who is a GM service tech said the ticking noise could be the rotor hitting the cap? Any ideas?
Old May 21, 2006 | 12:23 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Sounds like the classic oil pressure sending unit wire stuck under the dist. cap making it cockeyed and ticking while grounding out the oil pressure sending unit syndrome.
Old May 21, 2006 | 01:30 AM
zrated57's Avatar
ya know, that actually sounds like a very good prediction. its strange tho, the gauge has always been pegged out, but the ticking just started a few days ago. odd indeed. but thanks, i will def. check that out.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
