Key stuck in ignition
Old Jun 19, 2006 | 06:42 PM
Slow2.8's Avatar
My key as the title says is getting stuck in the ignition, sometime it will come out ok, other times it wont come out at all, I turn to get it (towards me) and it does not turn all the way (to the notches line up) whats the deal???
Old Jun 20, 2006 | 08:13 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
spray some good lub on the key and put it in slowly. keep spraying the key while putting it in a little further each time.
If this does not work for you take the steering wheel apart off and take the collumn apart untill you get to the ignition cylinder out and then spray it down.
If that does not work take the cylinder to the lock smith with your key and tell him or her to "Get Her Done!"
Old Jun 20, 2006 | 05:22 PM
Slow2.8's Avatar
well right now the key is stuck, it doens't even come out...
Old Jun 20, 2006 | 05:45 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
put it in park
Old Jun 20, 2006 | 05:53 PM
jamon8's Avatar
Engine: 350 tpi
take column apart and take lock cylinder to locksmith
Old Jun 20, 2006 | 05:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Before you get too carried away. Try a shot of Lock-Ease (or perhaps even WD-40) with the key in the lock.
JamesC
Old Jun 20, 2006 | 06:11 PM
Slow2.8's Avatar
JamesC
will try the wd-40... put the car in park? haven't thought of that one yet
Old Jun 20, 2006 | 07:01 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Hey, it happens.
Old Jun 21, 2006 | 06:17 PM
Slow2.8's Avatar
Well I put it in park and voila....
wait, it was already in park the whole time and the keys stilll stuck
RedLeader289
Sep 23, 2015 06:50 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Denricci22
Sep 18, 2015 09:02 AM
TexasMaro
Sep 15, 2015 06:50 PM
383cam
Sep 9, 2015 06:01 AM
