How many people are running a 400 combo?
Old Aug 15, 2006 | 09:51 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
Well it seems these days, that every magazine has a car with a 400 in it. Maybe i just notice cause that is what i had built. Anyhow, post if you have a 400 combo, i.e. 406,415,454,etc. (sbc) And if you know your power numbers, throw them in too. here's mine. should make 500-525 hp.
Old Aug 16, 2006 | 12:14 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Looks nice! Not sure of what you're combo is, but 500-525 HP is a TALL order....unless you're spraying. Numbers are in my sig, and that's FWHP, not RWHP.
EDIT: -And those numbers are from BEFORE I installed a retro-roller cam and MSD pro billet dist.
Old Aug 16, 2006 | 06:39 PM
Car: 87 iroc
Engine: 410 sbc
it's running 11.1 to 1 compression. should be about 500-525
Old Aug 16, 2006 | 06:50 PM
JesasaurusRex's Avatar
I don't have actual dyno #s but I have a trap and race weight calc #.
129.89 trap 3000lbs = 513 rwhp
pump gas (91 octane) no power adder
Old Aug 21, 2006 | 11:44 AM
Car: 87 iroc
Engine: 410 sbc
anymore??
Old Aug 21, 2006 | 02:13 PM
Damon's Avatar
Not currently, but I have many times in the past. Even with super mild 400 combos low 13s on street tires was easy. Put some traction to it and 12s were a no-brainer. Get a more serious combination going and the "super mouse" can really roar.
I remember a couple years ago my brother had an 87 GTA with a very mild 400 under the hood topped by a set of Trick Flow G2 heads a TPIS MiniRam and an off-the-shelf TPIS chip. The engine finally flattened a lobe on the cam after running strong for a year (it was the 3rd time I had reused that particular cam). We decided to stab in a Comp 270 Magnum cam which is still a pretty mild 224/224* grind. We thought it was fast before, but with the slightly larger cam it really came alive on the top end.
How alive?
Well, we ran a Corvette ZR-1 (the Vette with the 400HP 4-cam motor in it from the early 90s) in it. Did it from a highway roll. Just walked right away from him, getting stronger as we went. Tried it a second time, giving him the jump and proceeded to walk him again after playing a few seconds of catch-up. Lotsa fun.
Another story..... a very mild carbureted 400 in my old 79 Malibu putting power through a stock stall converter, highway rear gears and running a 150 plate shot cranked off an 11.99 @ 116 ON STREET RADIALS- not DRs.
I don't have any 400s in my stable now but I'm sure I will again in the future.
Old Aug 21, 2006 | 10:47 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I don't have one but after reading tons of mag build ups, posts here and seeing the power they put down at the track, I am definitely planning a build up.
I am considering starting with a built shortblock and going from there. Coast performance has an all forged version that I am considering.
Old Aug 26, 2006 | 08:01 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Well I have a 406 on the engine stand waiting for this winter to go into a RX7. Combo is balanced/zero decked 406 10.7:1, etec 200 heads, super victor jr. intake, HP 750 carb,comp cams XE sft 236/242 .534/.544 with 1.6 rockers. I am hoping for 475 to 500hp. Seems guys with similar combos in a 383 make 450 on engine dyno so I am hoping for similar #'s. I wasn't going to dyno but maybe I will, have the pros break the cam in/seat rings etc etc.
Old Aug 26, 2006 | 08:11 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ive thought about putting the 400 i have in the 82
might still do it, not sure
in stock form it doesnt put much more power out than a 350 the same year, but does put out good torque
hmm
Old Aug 26, 2006 | 08:24 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
hmm
or you could give me that 400 to put in my 82...you know for all the help ive been....but seriously? wanna sell it?
Old Aug 27, 2006 | 02:25 AM
ohyeahjay's Avatar
406 with holley 750 V.S carb, victor jr. intake, protopline iron heads, keith black pistons, about 10.5 compression, 6" rods, comp cams extreme energy cam, 1.6 roller rockers, 1 5/8 long tubes, all msd ignition car weighs about 33-3400 with driver and runs 12.6, 3.73 and turbo 350 tranny shifting at 6000. i think that makes about 425 hp maybe?
Azrael91966669
25
Jun 20, 2017 04:04 AM
BlackphantomZ28
Apr 24, 2016 08:14 AM
camaro71633
Sep 1, 2015 10:24 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
