1.7 Ratio Roller rockers
Old Oct 13, 2006 | 01:20 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I have been doing a lot of studying lately and have found many diffrent rockers.... I Found some roller rockers that are 1.7 ratio and require the 7/16's studs and I am wondering can you just swap the studs (since they are screw in's in my trick flows) to the 7/16's and install the 1.7 ratio's? I am planning a cam swap and correct valve springs for the adventure but just wanted to know if anyone has used the 1.7 ratio before?
Old Oct 13, 2006 | 03:58 AM
ede's Avatar
ede
would the 1:7s be for a LS1 by any chance? i doubt you find 1:7s for a SBC, except the LS1
Old Oct 13, 2006 | 09:26 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
You will probably need to upgrade to better push rods with 1.7 rockers. That may lead to a clearence problem for the pushrods going through the head (depends on the heads...) I wouldn't go that much on a street car. Instead, get a bigger cam (roller).
Old Oct 13, 2006 | 09:36 AM
izcain's Avatar
Engine: 584
Well these were for SBC not for LS1 and this isn't a street car so im not to concerned about thar....... The pushrod problem did come to mind but I guess I will have to contact some of the manufacturers about it.
Old Oct 13, 2006 | 11:03 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Superstock engines have used 1.7 rockers. I cant add much other than they use shaft assemblies.
Old Oct 13, 2006 | 09:17 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Swapping the studs is no problem. Just make sure the dimensions are correct on the thread length at both ends. I would think that a 1.7 rocker ratio might cause problems as mentioned above. You would need to make sure that there is clearance in the heads. Also that the pushrod does not contact the rocker arm at full lift.
You will also have to make sure there is enough spring clearance to stay out of coil bind and the recommended .050-.060" spring coil clearance at max lift. With the high lift cams available maybe the 1.6 rocker ratio might be enough. There are also 1.65 ratios out there. And last but not least the decrease in the life of your valve train componets. Make sure to use the best if you decide to go that route.
Old Oct 13, 2006 | 10:45 PM
izcain's Avatar
Engine: 584
Well the problem I have is that I ran a forged I-beam rod instead of a H-beam capscrew style and when I clearance it I did it for the cam I am running now which is a .501 so I can't run much more then that. I guess I might just pull it back apart and put in some H-beams instead so I can go to a much more aggresive ramp. If I did do the rocker swap I would of course change to the proper springs so that coil bind would not happen as well.
Old Oct 14, 2006 | 01:07 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
On my race motor in the dragster we run 1.85 on the intake and 1.80 on the exhaust. Of coarse you have to check for proper clearance and stay out of coil bind.
I would say that "the recommended .050-.060" spring coil clearance at max lift" that 1989GTATransAm listed is way too close. I would say that you need to have .100 minimum clearance. Of coarse if it is an all out race motor you can run it a bit tighter.
I run .075 but we run huge valve spring pressue and a rev kit. I turn the dragster motor over 9600 through the lights.
Old Oct 14, 2006 | 01:14 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
9600 RPM on a pushrod motor?!?! geez, is that even possible???
Old Oct 14, 2006 | 01:20 AM
izcain's Avatar
Engine: 584
Hey comp, so did you clearance the heads for the extended rockers or do they just fit? The only thing I am wondering is pushrod geometry and wether or not they will not go at to much on an angle.
InfernalVortex
Apr 20, 2021 11:31 AM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Vincent135
Sep 28, 2015 10:50 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
