How's my new combination look?
Old Oct 23, 2006 | 02:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I parted out my topend in my sig, I am going with the brand new afr eliminators 195's. Mini ram, hooker longtubes, and powering all this is a new comp xfi cam at 242/248 duration 284/279 lift 113 lsa. I was just curious if this cam might be too aggressive for what I have. I want 11's NA. Oh ya im ditching the 42's prolly going back with 24's
Old Oct 23, 2006 | 02:25 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
should make it.. i have a similar setup but im a carb boy cause they're just better
Old Oct 23, 2006 | 05:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You should get an award on these boards for fastest mover and shaker. I've seen a handful of your threads, and i'm always amazed by how fast you move.
Excellent!
What's the spec'd powerband on the miniram? I assumed Mini - lower end power. Not well versed in it, obviously.
That cam/heads would be best in the higher RPM range though.
Anything available to you inbetween 24 and 42lb injectors ?
Old Oct 23, 2006 | 05:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thanks for the compliment Sonix, I like to get **** done. The mini ram is for top end power, up to 6500-7000k rpm. Thats why I am going with big duration cam and high flow heads. Their are plenty of options of fuel injectors, I just want to go with near stock injectors for this fresh engine, get some dyno pulls and see how much bigger i really need to go.
Old Oct 23, 2006 | 05:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
oh ok. I always thought miniram < superram, etc...
Fair enough. 195cc normally is considered too small, but I think since it's AFR's new eliminators, you're gonna be fine.
It should do the job very well. I'll look forward to seeing you post the new dyno results. Should be up by friday right?
Old Oct 23, 2006 | 06:02 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Lol. I wish, I havnt purchased the parts yet, Should have them within a few months and running. I think I am picking up new pistons as well.
Old Oct 24, 2006 | 10:13 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Given any thought to a solid roller?
Old Oct 24, 2006 | 10:39 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Very nice man. Why you selling the stealthram?
Old Oct 24, 2006 | 11:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Old Oct 25, 2006 | 01:02 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Don't wanna deal with a solid roller, Stay hydraulic. Selling stealth ram so I can run a little bit bigger intake runner.
Old Oct 25, 2006 | 05:17 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Looks pretty good. Ill be running pretty much the same on motor and comp ratio but Im getting, AFR 210 eliminators competition versions and a TPIS ZZX cam with 1.6 rockers.
Old Oct 25, 2006 | 12:47 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I am thinking about finding some 210's instead, I may be picking up a procharger here shortly.
InfernalVortex
Apr 20, 2021 11:31 AM
Hawk312
Aug 22, 2017 08:55 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Reborn756
Sep 4, 2015 03:42 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
