Engine combo from Trick Flow
Old Jan 15, 2007 | 07:33 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
I was just curious what everyone thought of this engine combo from trick flow, and weather or not it would work with a 92 5.7l tpi motor. Doesn't specify if it does or not. Thanks for having a look.
http://store.summitracing.com/partde...0&autoview=sku If the thread doesn't work this is the part number
TFS-K315-465-450
Old Jan 15, 2007 | 08:07 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Its definatly a nice kit but for 2k im sure you could do better.... thiers no way your gonna make 465hp on a stock tpi system you would also have to buy a bigmouth base for it because the stock one is really restricting and also you would need an lt1 style mini ram or some other short runner intake system. tpi by itself is a good system but has too many restrictions to try and upgrade heads and cam without doing the hole intake system.
Old Jan 15, 2007 | 08:31 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
The cam might be little hard to tune for if your keeping EFI.
Old Jan 15, 2007 | 08:44 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
I've already upgraded to the edelbrock intake and large runners, also have headers and catback exhaust. If not this setup what would work good and give me the most "bang". I'd like to stick with the trick flow heads tho. Thanks
Old Jan 15, 2007 | 09:02 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Couple of thoughts. Those Trickflow heads have 72cc combustion chambers. IMHO those are to large for a 350 motor. You need the 64cc versions.
Like was said above that cam is to big for most TPI setup's. You would be better off with one that has smaller duration and high lift.
I think you can do better for less money. The Trickflow heads are very good and I would have no problem sticking with them. It's the other parts you can do better on for your combination.
Old Jan 15, 2007 | 09:22 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
I appreciate the insight. Any thoughts on a good cam that would work well with those heads?
Old Jan 15, 2007 | 09:38 PM
Car: 1989 GTA
Engine: 369 TPI
The Trickflow head I used on my last combo was number TFS-30400007. Made well over 400hp with a small cam. If you can afford it get the TFS-30400007-CNC version if you are going to put them on out of the box. I did that with the non CNC version and had very good luck. The choice is yours.
As to the cam for a long tube runner setup. I like high lift shorter duration cams. The one I chose for my current set up is the Comp Cams XFI 268 cam. If you go that route get the Comp Cams Pro Magnum 1.6 rockers. Also get the best pushrods you can afford.
Old Jan 21, 2007 | 12:25 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Well I just about have everything picked out for this and ready to order. I'm going with the TFS-30400007-CNC heads and the XFI268HR13 cam, I'm also going to get the Comp cams Pro Magnum 1.6 ROckers, question is will these fit under the stock valve covers? Cause with the larger runners I don't think I can run tall valve covers. Thanks for the help
Old Jan 21, 2007 | 12:33 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The Trick Flow heads with 195cc intake ports & 64cc chambers is the way to go,, but I still prefer AFRs. As someone stated above, the cam seems to be more suited for a carb and high RPM. For the cam, I would not go above a 224/230. And the 110* LSA is not computer friendly. For an EFI car, dont go below 112* LSA, and 114* LSA would be best.
Old Jan 21, 2007 | 12:49 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
well the lsa on this cam is 113 and it was designed to work with fuel and injection and be computer compatable
Old Jan 21, 2007 | 02:30 PM
Car: 1989 GTA
Engine: 369 TPI
You will be fine. I used longer rocker studs on my Dart Pro One 200cc heads and had to get the taller valve covers. With the Trickflows you should have no problem using the stock covers. Expect some serious horsepower.
Old Jan 21, 2007 | 02:46 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
The heads come complete with the rocker arm studs so I just need to get the nuts for them. The also come with the guide plates so I'll need to non-self aligning rocker arms. Now about pushrods, I want to get the hardened pushrods but what length do I need? Will stock work fine or do I need to assemble this and then check for an exact length? Thanks I appreciate the help.
Old Jan 21, 2007 | 06:10 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I checked your Summit Racing link, and it sais 110* LSA for the cam. At least I thought thats what I read.
I just double checked it, it is 110* LSA.
Old Jan 21, 2007 | 06:18 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
I have to disagree with this. I have had the TFS heads with 64cc chambers on my Xfire Vette for at least the last 5 years and found them to be excellent. But in particular, I must disagree with the statement that a cam with less than a 110LSA is not computer friendly. Mine is a 108 and idles very nicely thank you. It takes tuning and RBob's EBL really helps. My currnt cam is smaller than the 224/230 that doc is suggesting, but it matches the flow of the heads. Overall, a great combo. I'd recommend it to anyone.
Old Jan 21, 2007 | 08:08 PM
Car: 1989 GTA
Engine: 369 TPI
The Comp Cams XFI268HR13 cam is indeed on a 113 lsa. Your Pro Magnum Rockers will come with the nuts and other hardware you need.
Old Jan 21, 2007 | 08:20 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Alright thanks for all the input. The cam is on backorder but I should have everything by the end of the month. I've been wanting to get this done before I go over seas so I really appreciate the help. The wife is finally letting me spend some money. Hopefully all will go well with the install.
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
tmellott89
Aug 16, 2015 02:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
