Bosch Platinum 4 Plugs
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
I put Bosch platinum 4 spark plugs in my car the other day and I was advised the next day by the guy at autozone that these plugs will just give me problems. Anyone have any ideas or comments on this? I paid to much to just wanna yank them out. Seems like he would have told me this before I bought them.
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Yank them out, you should never EVER buy BOSCH plugs!!!! NEVER EVER! Those 4 PRONG PLUGS are not made for our engines they are JUNK!!!!!!!!! Yank them out.
I highly recommend using AC DELCO RAPIDFIRE spark plugs. they sell them at PEP BOYS.
Don't use AUTOLITE either.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Junk, pull them and toss them as far as you can into the neighbors yard
These engines like the no-name 'bottom of the barrel plugs' like the champion coppers or delco plugs.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
They will give you nothing but problems unless you have an upgrade ignition (MSD, etc). They fouled in my truck after 2 weeks of driving!
Thanks for the advice I will yank them out tonight. Are champion plugs any good?
Car: 1988 Firebird
Engine: 2.8 liters of fury.
Axle/Gears: Stock
I use Bosch in my Land Rover with no problem. I personally have had no problem with them in any of my cars. I have heard that american cars just do not like them. If you pull them out and contact Bosch, they will pay for the plugs. +4 plugs only have a real use in Hondas and imports. The spark won't split four ways,it will just go to the closest point. Good Luck
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Bosch stuff is just crap in general. They use the screw-off terminals as well, which can back off and cause serious igntion problems. A/C delco or any reputable plug with a standard electrode and solid terminal is the way to go. If it has funky electrodes or screw-on terminals, pass for something else.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
[QUOTE=rx7speed;3242149]and let me guess ngk are for asians right?
QUOTE]
NGK are manufactured in 7 US states and are one of GM's top suppliers
QUOTE]
Axle/Gears: 9-bolt/3.45
to say that Bosch plugs are "engineered" ONLY for German cars, is patently ridiculous. Electrons are notoriously non-patriotic. Their rules of behavior do not change when they cross borders. They don't look at the engineer's nationality or even the car mfr's headquarters city and decide accordingly whether they are willing to jump that gap. That idea is as absurd as saying that AC or Champion plugs will only work in American cars, or that Nippondenso (Accel) or NGK plugs will only work in Japanese ones.
And it only stands to logical reason. One cannot really fault the electrons, either. Having comingled with so many other staunchly nationalistic, even jingoistic atomic particles in lower valence bands, such myopic particles would only be expected to bear right and rigidly follow their patriotic paths, shunning all those that may differ from them, lest they become inferior, bastardized particles to be chastized by their more righteous peers, banished in their impurities from the one, true microcrystalline order of their origins. No electron would wish such a fate on even its worst enemy.
I couldn't resist digging up some priceless posts I remembered from the past regarding this topic. It's been beaten to death.Just like with ANY brand, part or product, there are people who've posted they've had no problems with the +4s, and there are some who've posted they have had problems with them. So just use whatever you feel like trying or spending your money on, and you'll likely be just fine.
And because you've already got them installed, you might as well leave 'em in there, at least, for now. I don't think you can return them anyway, can you?
Im gonna yank them, I was cruising around this afternoon and it felt like it was missing. im just gonna put some plain old champions in.
From reading the other threads it seems that the people who had good results with those plugs also had high voltage aftermarket coils. I don't think our stock coil works well with those plugs.
I am looking to upgrade to super hei do you think these plugs will work better with that?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Don't ever use any multiple electrode spark plug. They do nothing but lighten your wallet and make you buy more Tylenol (Advil if you are German/Japanese).
Platinum or Iridium plugs are not a bad idea, as they can potentially outlast the copper plugs by quite a bit, but only the single electrode versions.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
in itself I don't see what is so bad about multigap plugs as that is what comes on my rx7 right now. they come in two versions either a full ring around the center electrode or the other style is like the full ring around it but it has four little grooves making it like a multi ground plug. they seem to work ok and last. so I wonder what the difference is between these NGK's and the bosch plugs.
though I know when I used the bosh in my camaro it worked great for a week then fouled out.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Last i checked their was never a rotary engine under the hood of my camaro or any other...
My old 350 didnt like the 'normal' bosch platinums with the single electrode. Chucked them and bought some NGKs. Currently running Delco's in the new 350.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
that may be but I dont really know if it is a problem with the multi electrode itself I just know at least that the bosch version sucks
Car: 92 camaro rs
those rx7 use some pretty funky looking plugs
almays thought rotary engines were kind of cool was going to put one in my s10
but as far as those +4 had a friendput them in his ranger the 4cyl that has 8 plugs and ended up frying out all his coil packs in 2 days
ever since then i wouldnt recommend them (an i work at a parts store)
just my .02
just my .02
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
ill go out on a limb and say that it has something to do with the way bosh makes them or the quality or materials. Come to think of it, no mater what style of bosch plug or the application, i dont recall anyone being overy happy with them...
I changed the plugs and wires and now she runs great. Thanks for the help.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
um yes all spark plugs arc that is the point of them... helps ignite the fuel/air mixture...without that you would have a really expensive gas pump..
Cutting back the electrode has been a motorcycle power added for a long time. The resulting spark is a lot hotter, but the plugs don't last as long.
Car: 88' IROCZ
Axle/Gears: 2.77
Does that apply to platium types as well? I would think platium, and iridium would last longer even if the strap is trimmed.
The excess wear is evident on both... I never ran them long enough to find out which fails first. The plugs for my bike were so cheap I changed them often.
Car: 92 Camaro RS
Engine: 305 TBI
I believe platinum has a little more electrical resistance than iron does too, so it takes more spark energy to fire a platinum plug, add a old ignition system and a little oil burning to the mix and you could have problems.
BumpaD82
Feb 26, 2016 02:57 PM
89 formula TPI
Sep 7, 2015 11:06 AM
