smoke from oil dipstick
Old Feb 27, 2007 | 08:41 PM
goldens98's Avatar
got car back from mechanic finally it took him 2 weeks to put in some valve stems. He had to take off ac equipment and jack the motor up. The idiot bent up my oil pan, but all that to the side the care runs fine but I noticed smoke coming from the dipstick. the motor isn't overheating or anything. Just wondering what could be the problem. PCV is working properly.
Old Feb 27, 2007 | 09:04 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
not a good sign, check compression. hopefully everything is just breaking in
Old Feb 27, 2007 | 09:29 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Not a good sign at all. Is there smoke from the oil filler cap?
Old Feb 27, 2007 | 09:38 PM
goldens98's Avatar
no smoke from filler cap, but the dip stick has been moved a little. No oil leak
Old Feb 28, 2007 | 07:59 PM
bmfIROC-Z's Avatar
kinda sounds like blow by.
Old Feb 28, 2007 | 09:07 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
if this "mechanic" was replacing valve stem seals how the hell did he dent the oil pan? why did he need to jack up the engine? when is he replacing your oil pan?
if it is smoking out the dipstick then it will probably be smoking out the oil filler cap on the valve cover also you just havent noticed yet
so either it is mysterious occurance of blow-by which just happened to coincide with this "mechanic" going shade tree on the cars *** or he screwed up a head gasket...
Old Feb 28, 2007 | 09:38 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
It's probably steam, not smoke, from condensation building up while it was sitting. And if it is smoke then you want to do a leakdown test, not a compression test. A compression test would tell you absolutely nothing in this case.
I do agree though that there is absolutely no need to jack the motor up to replace valve seals.
Old Feb 28, 2007 | 10:01 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
If the oil pan is dented, could that also have screwed the oil pump pickup?
Old Feb 28, 2007 | 10:13 PM
Car: 91 RS
Engine: 350 vortec
yes it could have more severely depending on where the dent is but again there is no reason the engine should have been jacked up for this.
Old Mar 4, 2007 | 07:56 AM
curtistimmerman's Avatar
smoke out of valve cover breathers
I have a 350 that was rebuilt a couple of years ago,bought it a couple aof months ago and tore it down to re-gasket the engine ,due to time,everything lokked great inside when reassembling,finally got it running and noticed alot of smoke coming out of the VC breathers does not have a pcv any help?
Old Mar 4, 2007 | 09:34 AM
Dialed_In's Avatar
Yeah it's because you don't have a PCV system. Any engine will have a certain amount of blowby. The gasses end up in the crankcase after they're pushed past the rings. Without a PCV system to evacuate the crankcase of these gasses, pressure builds up and will escape through the weakest point which in your case are the breathers. It can get bad enough to where the pressure can actually blow out gaskets. Put a PCV system on it and your problems will disappear as long as the rings aren't totally shot.
69GTOby
Apr 18, 2016 02:34 PM
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
