Oil Pressure Sending Unit 1991 RS...
Old Mar 12, 2007 | 06:41 AM
tlgrooms's Avatar
Car: '69 Camaro/'91 Camaro/'93 Camaro
Engine: 307/305/350 LT1
Transmission: Powerglide/Auto
Anyone have a picture showing where this is located on a '91 RS? and a picture of the piece itself?
Old Mar 12, 2007 | 07:26 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
cant miss it, it is right behind the rear end of the intake at the center of the engine(middle of the car) close to the firewall, a single wire plugs onto it it is a round metal barrel/bell shaped unit there not much room around it
good luck
Old Mar 12, 2007 | 08:01 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Are you sure? On a 91? On my 92 GTA it's the long silver thing-a-mabob screwed in just above the oil filter.
I thought the bell-shaped senders went out around 1987.
Old Mar 12, 2007 | 08:16 AM
j dezzy's Avatar
Car: 87 TA
On the V6 engines the unit is just above the oil filter. but on a V8 it should be right where Randy said.
Old Mar 12, 2007 | 08:21 AM
j dezzy's Avatar
Car: 87 TA
I called a friend of mine just now that has a 91 RS 305 TBI and he said it's under the car on the driver side, below the engine area and the exhaust manifold in front of the exhaust manifold in the block. hope that helps...
Old Mar 12, 2007 | 08:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Both being V8's.....and tlgrooms info states he has a 305......
My 88 is on the rear china wall just how Randy stated.
However, my 92 is the long silver thing just above the oil filter.
His being a 91 305, one or the other location should be correct.
Old Mar 12, 2007 | 12:12 PM
Damon's Avatar
On my wife's all-stock 92 Rs with the 305 TBI motor it was screwed into the block just above the oil filter boss.
Old Mar 12, 2007 | 07:20 PM
djwimbo's Avatar
Car: 91 camaro T-Tops
Transmission: Borg T5
I just replaced my sender unit less than a month ago. (L03/305 TBI) any SBC should be about 2-3 inches above the oil filter on the left side of the eng. and about 3.5-4" long. Mine had, I think, a 3 wire connector on it, and it's a pain to remove unless you have the special socket made for GM Oil press Sending UNits. I think mine was $21.95 from Napa. Took about 10 mins to change once I had the right tool for the job. Since then, NO LEAKS - on a GM!! woo hoo. any way it's easy, doesn't take long and definately do it yourself. Just be gentle at first loosening it. It's only a 5/16ths hole and a 1 1/16th socket(I think), it can break off in there, but very unlikely.
Old Mar 12, 2007 | 07:41 PM
djwimbo's Avatar
Ok, so I lied, it is still leaking oil. My bad, any way here's pics of where it is in MY L03 1991 RS camaro.
Old Mar 12, 2007 | 09:55 PM
tlgrooms's Avatar
Many thanks for the replies guys. Found mine today, just above the oil filter in the block and man was it a pain to get out. Went to the parts store and bought a sending unit, and the special socket to get it out. Got home and the socket wouldn't fit. Took me an hour or so but I finally got it out. The one I took out was larger than the one they sold me. Seems to be working fine tho and my gauge is back to normal. Hope it stops some of my oil leaks. Too soon to tell yet tho.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
