old cam, new lifters
Old Apr 14, 2007 | 12:00 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
I'm having my 350 that died rebuilt again and the machine shop said the cam was salvageable, but the lifters were not. I thought you weren't supposed to use an old cam and new lifters, or is it the other way around?
Old Apr 14, 2007 | 12:14 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: old cam, new lifters
well you can use a new cam with new flat tappet lifters or a old cam with new flat tappet lifters or a old cam with a matched set of old lifters
Old Apr 14, 2007 | 12:39 PM
84 t/a 5.0's Avatar
cool, i thought that was the case. thanks
Old Apr 15, 2007 | 03:01 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If the lifters are shot, the cam is too.
Old Apr 15, 2007 | 03:06 AM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
What if you just have few that are not pumping up the way they should? That's what I have going on with my truck. I don't think the cam is bad it's just did this after it sit for awhile apart. One or two lifters refuse to pump up.
Old Apr 15, 2007 | 04:25 AM
F-BIRD'88's Avatar
If the lifter foot is visibly cupped, the cam is also finished.
Lifter are not flat, they are slightly convex. put two together, foot to foot. if they will not rock slightly, one or both are shot.
Usually the cam is shot too. Flat tappet hyd cams are cheap. Its not worth trying to save the cam unless it is a expensive custom grind and looks and measures pristene. A new $69 Summit generic cam and lifter set is hard to beat. Your hyd lifters are either infected with dirt/metal fileings (could be a warning of internal engine wear) or cheap offshore junk.
When I tear a motor down I'll only save the cam if all the lifters are good. If any are cuped or flat, I toss the cam.
Old Apr 15, 2007 | 06:26 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Your having a engine rebuilt and your trying to save 100.00 by using old cam? When the motors back together, you will be kicking yourself everyday.
Old Apr 15, 2007 | 12:27 PM
84 t/a 5.0's Avatar
well, it was a "new" crane 2050, and the engine died with only like 1500 miles on it. I guess it does make sense to just by a new cam and lifter set, think it's only like $150
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
