how much do our cars weigh?
Old May 1, 2007 | 01:35 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
not sure where to put this post but, how much do are cars weigh stock?
Old May 1, 2007 | 01:53 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: how much does are cars weigh?
Depending on year,options and engines ect, anywhere from about 3500lb+
Old May 1, 2007 | 03:12 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
damn i didn't realize these bastards were so heavy, im gonna have to go back to my notch fox
Old May 1, 2007 | 03:14 PM
blue_roc's Avatar
Car: 1986 Iroc Z28
Engine: LG4 5.0
Transmission: 700 R4
If I remeber right, my 86 Iroc weighs about 3200 pounds. It's got power windows, ttops, all that junk. All depends on what you have.
Old May 1, 2007 | 03:47 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
https://www.thirdgen.org/forums/susp...t-invoice.html
Old May 1, 2007 | 07:03 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Sorry to be an AZZ but I had to:
ARE-present second singular or present plural of BE
OUR-of or relating to us or ourselves or ourself especially as possessors or possessor, agents or agent, or objects or object of an action
Old May 1, 2007 | 07:55 PM
Damon's Avatar
3300-3400 sounds about right for typical V8 cars. Some can weight more due to options. Putting my brother's 87 fully-optioned GTA on the scale spat out an eye-popping 3700 lbs!! The 6-way adjustable power sets must have weighed almost 80 lbs. each.
Old May 2, 2007 | 03:43 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
these cars are actually pretty light for their size especially
hard to find anything lighter and this size,
most car models were heavier by 4-500lbs, some by not that much more even though, but very few, although whats funny is that the 72 and older trucks were under 4k lbs, especially the short bed and the K-5's the longbeds were right on about 3800 with driver like my first 68 (long fleet pickup) was, the shortbed were 3-400 lighter and coil spring rear with trailing arms from factory to boot and lots were 3.73 axle too mainly the 6 cyl, and the manual trans ones though (307 and SM326 for example like my first 68 was)
but simple things can be done to lighten up any vehicle without making any noticeable modifications, including aluminum or glass hoods/fenders, aluminum bumper frames, aluminum wheels, drums, heads, driveshaft, and so on, all these aluminum parts were made and are out there in factory form- for these cars especially
can lose tons of weight really quickly/easily
good luck
Old May 4, 2007 | 09:18 PM
Midnyte81's Avatar
Car: 1984 Z-28
Engine: 350(bored 0.060)
Transmission: Probuilt TH700-r4 tranny with the w
Axle/Gears: 10 bolt 7.5" posi 3.42
If you really want to lose weight, do what I did a few years ago and take out the a/c comperessor, canister, exhaust system (With the exception of turn down tubes for the headers), substitute for lightweight aluminum alloy wheels (Centerline made some a few years back that were 10 lbs together and rated for 500 ft/lbs of tq), aluminum rotors and driveshaft, as already stated, no sway bar, lightweight forgings, aluminum heads, one racing seat, no interior, dieting. All of this got me cold as hell in the winter months, hot in the summer, and a blown engine in my former Forebird for accidentally pressing the nitrous button at 1500 rpm on the highway. You should have seen it. It was amazingly stupid for a 20 year old at the time. Lesson learned though (Always have an arming switch).
Just my 2 Cents
Old May 4, 2007 | 09:20 PM
Midnyte81's Avatar
Car: 1984 Z-28
By the way, the car weighed 2600 at that time
Old May 4, 2007 | 10:11 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it would take a LOT more than that to get the car down that light.
Old May 5, 2007 | 12:45 AM
Midnyte81's Avatar
Car: 1984 Z-28
It was that light. At the time, I had the money to blow to get it that light. I didn't put all of what I did to it in the post, but if you go back under my sig, you'll see it. Some of the older guys in mid Ga probably remember seeing the wreck on TV. As I said before, it was amazingly stupid. I could have spent the money on better things, even if I still spent it on the car.
Old May 5, 2007 | 03:01 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
Re: how much do our cars weigh?
92 camaro rs, auto v8, power everything except seats, what do you think that weighs in at?
Old May 5, 2007 | 09:14 PM
patgta's Avatar
my 1988 trans am 5L tpi, auto, t-tops, power everything except seats = 3320 with about 3/4 tank full and no driver.
most of our cars (v8s) weigh in between 3200 - 3400.
pat
Old May 5, 2007 | 11:24 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
my car is pretty light, v6 body, NO options, aluminum heads. the shipping weight with the v6 was around 3000 so i suspect it to be around 3200 with the v8. i really need to get it on some scales(and put back together for that matter).
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
